Results 1 to 10 of 18
Thread: Shocking isn't it?
    Constant Bitrate supralightning's Avatar
    Jul 2003
    Shocking isn't it?
    Ok, yesterday i had my inverter going for a test run of the carpc. My friend noticed that she kept shocking herself everytime she got out of the car (like static charge shock not electrical). I don't remember anyone having this problem before (inverter is under passenger seat). Is the inverter transferring some current through the seat or what could be going on here?
    -EvoXTC
    Vehicle: 2003 Mistubishi Evolution
    PC Specs: 1gHz Nehemiah M10000
    512mb RAM
    Windows XP Professional
    80gb 7200rpm 8mb cache HDD
    UI: MediaEngine 2.1
    Maximum Bitrate none's Avatar
    Sep 2003
    Does it still happen if you disconnect the inverter?
    Jul 2003
    Not exactly sure....we didn't take notice of the shocking til' last night which i had the inverter on. If i knew that then i would have already come to my conclusion.
    -Evoxtc
    512mb RAM
    UI: MediaEngine 2.1
    FLAC Mastero's Avatar
    Aug 2001
    India
    Its always better to go with dc-dc PSU why does one want to play with AC current in a car which goes through so much of bumps and speed....
    Check the car chasis with a tester the for charge !
    Mastero
    Jan 2004
    Quote Originally Posted by supralightning
    -EvoXTC
    This isn't exactly abnormal for any car especially in the winter months. My wife's car will shock us EVERY time we get out of the car in winter- my solution is to not touch any metal when getting out if I can avoid it. I wouldn't worry to much about it unless someone get knocked on their a** by the shock.
    Dec 2003
    Michigan
    Quote Originally Posted by Mastero
    Kinda a rant here, but just because dc-dc is better for you does not mean that it is better period. DC-AC-DC is MUCH cheaper, and then allows you the ability to run ANY household device in the car. You pick any computer related product you might ever want to run in the car, and we'll compare who can get it working first. Say a wireless router, or a LCD screen, or perhaps a force feedback joystick? I can run it all off the inverter, what about your DC-DC supply? Sorry for the rant, I'm just tired of seeing everybody claim that DC-DC is the solution for every power/static/humm/distortion problem posted.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
    Feb 2003
    SE Ohio
    Quote Originally Posted by Jackso
    just because dc-dc is better for you does not mean that it is better period. DC-AC-DC is MUCH cheaper... ...tired of seeing everybody claim that DC-DC is the solution for every power/static/humm/distortion problem posted.
    Amen Jackso. I think a lot of the problems people experience with DC-AC-DC systems is due to improper shielding and ineffective grounding. As my install progresses I'm going to be adding another Alternator and grouding it out to the Car Battery & alternator, and also installing a copper grounding strip that will run the length of the car. This way I KNOW that grounding won't be an issue if problems arise.
    If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    1985 Supra 7M-GTE
    10.4" Planar LCD
    ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
    Edimax EW7318USG Wifi w/ 7 db Ant.
    USB GPS
    Aug 2001
    India
    I agree with you friend you can not use a blow dryer with a dc-dc solution.
    My feel is AC 110 / 240v should be kept away from cars.
    Rest is upto.. you
    Mastero
    Sep 2003
    Rest is upto.. you
    Mastero
    Agreed. Notice that the people defending inverters are usually the same people who can't get their systems working right in other threads.
    Newbie Chosen1's Avatar
    Nov 2003
    Jacksonville, Florida
    I have both....DC-DC for pc, inverter for Xbox, etc.
    Can't we all just get along?
    -Chosen1
  1. shocking !?
    By oddcomp in forum Power Supplies
    Last Post: 11-21-2002, 08:16 PM
