Results 1 to 6 of 6
Thread: PW-70a alternatives...
    Jan 2004
    Italy
    Hi all!
    Are there PW-70a alternatives out there?
    I mean, better and/or cheaper solutions... especially cheaper...
    my project is to use my carpc also as a htpc, so it has to be removable.
    So I want to put a pw-70a or something similar into the pc, then attach an ac/dc converter for home use and a dc-dc for car use...
    any link/idea/sugestion is welcome....
    thanks in advance!
    bye
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The best alternative is the Opus for car use.
    However that won't be brilliant for indoor use, unless you have a good quality 120/240-12V transformer. That also goes against your "cheaper" recommendation.
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    the pw-70a is probably most conveinient for what you're doing. Run wires from your battery to your regulator (ITPS i would assume) and run wires to a DC Plug, like this (i don't know if that's the right size, but it's a pic) and then plug it into your pw70a. That way, you just uplug the DC jack, bring it inside, and plug it into this. (there are cheaper places to get something like that, like www.idotpc.com or something).
    Edit: That is probably the cheapest option for a DC-DC power solution, coming in at around $110. (ITPS, PW-7a, and wall adaptor)
    Or you could go the inverter route, and probably spend $30 on an inverter, and $30 on a standard PSU. From a technical aspect, that's more ineffiecient than using a DC-DC PSU. But people who use inverters around here swear by them. So that's $60, but it's a lot more clunky than using the PW-70a and a Regulator which means the case is bigger, making it harder to move around as you wish to do.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jan 2004
    Italy
    Quote Originally Posted by Pudge
    thanks, It's the same idea I had, I would like to know if there is a product similar and cheaper than pw70a. Morex dc-dc converter should be a choice...
    I forgot, I'm Italian...In italy there's only one pw70 and morex reseller, but prices are prohibitive....
    thanks a lot!
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Morex will work in the same way, yeah.
    2 Kicker Comp 10"
    Check it out?!
    Jan 2004
    Italy
    I excluded inverter for those reason: space and efficency.
    I think I'll search for the best offer between morex and pw70a...
    Or mybe I've to change my question to: is tere any other compact dc-to-atx converter that fits in a small case (maybe a din-sized case)???
  1. PW 120 HDD Power up Issue
    By RX7FDTT in forum Power Supplies
    Last Post: 01-12-2004, 12:20 PM
  2. WTB: 60a or 70a DC-DC and ITPS
    By sniz55 in forum Classified Archive
    Last Post: 01-09-2004, 01:33 AM
  3. FS / Carputer in lexan custom case. With PW Inverter
    By handyandy in forum Classified Archive
    Last Post: 12-12-2003, 07:21 PM
  4. P4 power alternatives?
    By tejesh83 in forum Power Supplies
    Last Post: 06-24-2003, 11:47 AM
  5. Alternatives to a lead acid battery???
    By zzsprade in forum Power Supplies
    Last Post: 04-03-2002, 12:02 PM
