Results 1 to 4 of 4
Thread: Is 150w Opus enough?
    Feb 2004
    I'm not sure what my final power consumtion is going to be yet, so lemme just post what I'm gonna be hooking up. I used the calc to estimate 130w of power usage. Probably closer to 150 when its all done, if not more.
    Mobile Athlon XP 2400+
    Asus A7N8X-VM/400 (Onboard GeforceMX, LAN)
    512MB PC2700 Corsair
    Audigy2
    Three 80mm fans, one mouse/keyboard.
    40GB Western Digital (7200RPM, 8MB Cache)
    DVD Rom Drive (Pioneer 106s, 16X Slot Load)
    An 802.11b card (still deciding, plus external 5dB gain antenna (magnetic mount).)
    iTrek Mouse USB GPS (and external antenna)
    Also I'll prolly order the DWW-7VGA from digitalww... that thing is sweet lookin.
    (I've already ordered everything from the Mobile Athlon to the Hard Drive. DVD to LCD is still "up in the air" as to what I pick.)
    Alright, anyway. How well is the opus at supplying, say, larger than its rated capacity. Or, is opus looking to create perhaps a 200w PS in the future?
    Am I better off with an inverter?
    Thanks in advance,
    Kai.
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    Quote Originally Posted by kai445
    Audigy2
    I would have to say a inverter Im running a AMD 1700+ and when I try running my system with a 200 Watt AC power supply I get nothing not even 200 watts was enough to power it, Im running a 300 watt Inverter and a 300 watt AC power supply and it works.
    Thanks in advance,
    Kai.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I'm running a very similar setup, Anthlon 2000+, MiniATX mb, Onboard GeForce MX, NIC, Lots of USB, everything except the DVD drive and have no problem running it all on my Opus 150 watt. This same setup didnt run off a regular 150watt supply when hooked up in my house.
    The OPUS is a very capable power supply. I think you should be fine with it, but even if its too much you can always go external with the DVD and underclock it a bit and you won't have any problems.
    Audigy2
    Thanks in advance,
    Kai.
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Audigy2
    I have a similar setup. Once you do not put a high end graphics card then you would be fine.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  1. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 03:21 AM
  2. WTB: Used or New Opus 90w or 150w
    By antimatter in forum Classified Archive
    Last Post: 01-14-2004, 07:09 PM
  3. Does the Opus 150W have an ATX12V connector?
    By shchua in forum Power Supplies
    Last Post: 11-30-2003, 09:54 AM
  4. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
  5. Older OPUS 150w /w EPIA-M mod?
    By GTC in forum Power Supplies
    Last Post: 09-19-2003, 03:54 PM
