Results 1 to 4 of 4
Thread: USB Power
    Constant Bitrate GRUNT's Avatar
    Sep 2002
    Scotland
    USB Power
    Extracted a 3 port USB powered HUB from an old monitor.
    It requires 6.3v.
    What is the best way to drop 12v to 6.3v or up 5v to 6.3v
    Don't think it will require much amps!
    The power supply it used, input is 240v and dose not work.
    I have two max788 could I use them?
    If yes what is the eased way to connect them?
    Thanks for your help.
    Nov 2003
    VT
    http://www.radioshack.com/product.as...%5Fid=276-1778
    It even has schematics on the back- or at least it used to. If it doen't, let me know. I can throw a design together for you.
    Just keep in mind I think you can only get ~1A from it, and that's with a heatsink.
    Sep 2002
    Scotland
    Thanks Droswell,
    Found this link that shows how to use them.
    If I understand, When you adjust the resistance on pin (1) this adjusts the output voltage.
    With 12v input, min output=1,25v and max output=12v-1,25v.
    1,25v=Reference Voltage of the LM317T
    http://www.bit-tech.net/article/32/
    Nov 2003
    VT
    This will help too
    http://ourworld.compuserve.com/homep...den/page12.htm
    Gives you the whole diagram
  1. power to USB stays on during hibernate
    By ob1 in forum Power Supplies
    Last Post: 04-14-2004, 10:53 PM
  2. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  3. USB power & touchscreen issues...
    By Ren77 in forum General Hardware Discussion
    Last Post: 12-11-2003, 05:56 PM
  4. power consumption of a usb hub
    By cubanmoses in forum Power Supplies
    Last Post: 08-09-2003, 02:27 AM
  5. HELP! USB HUB FOR Laptop, how do I power it???
    By bankingdom in forum General Hardware Discussion
    Last Post: 05-21-2003, 07:33 PM
