Results 1 to 10 of 10
Thread: Via Epia M10000, MII-10000 Current Draw
    Newbie PSUSuperSenior's Avatar
    Jan 2004
    State College, PA
    Question Via Epia M10000, MII-10000 Current Draw
    I have on order a Via Epia MII-10000, for which I'm trying to size a DC-DC power supply. Does anyone have or know where to find current draw information for either of these units (which I believe are almost identical except for a few port locations and the MII's CF + PCMCIA daughterboard).
    I'm still deciding what speed HD to use and whether to include an external CD drive (I have one of the old-school Nakamichi 5-cd changer drives and all the necessary SCSI->USB2 cabling).
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    go to www.mini-box.com and use their power calculator... and if you didn't know, Power=voltage x current
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I'll narrow down your choices for Power supply:
    90W or 150W Opus Either will be plenty, but I prefer the added overhead of 150W
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Feb 2004
    Chandler, AZ
    I'll be using the 90w Opus for my M10000 Erza.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    is there a significant pricedrop between the 90 and the 150W?
    -Mars
    Feb 2004
    Chandler, AZ
    with a case on the thing, it's like a $40(us) difference
    Jan 2004
    State College, PA
    Thanks for the power calculator link... I couldn't find the draw for the Epia M for the life of me anywhere else... Anyway, I found a (supposedly) 120W power supply on ebay which I bought:
    http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EOT:US:3
    Any opinions on this (although its kinda too late?) The only thing that makes me scratch my head was the 7A rating on the +12 lead looks kinda photoshoped if you supersize that picture, but I'll find out when I get it.
    And yes, I realize I won't be able to mount it directly on the mainboard due to the MII's daughtercard, so I will just use an ATX extension cable
    1984 Fiero EV conversion:
    180VDC Saft NiMH 106Ah batteries, Solectria AC42 AC Induction motor and UMOC445 Motor Controller
    A few pics at http://www.paulminear.com/images/pic...EV_Conversion/
    Aug 2003
    Essex, England
    You'll probably find that:
    It will not regulate the voltage, therefore you will be putting 14ish Volts into your HDDs etc
    It will restart your computer when you start the engine
    It will not automatically start up/shut down the computer with the ignition
    Now you've got that, you'll probably have to spend another $200 for an Opus when you find it's not good enough. Instead of only having to save another $130 for the Opus
    Also, that PW120A is just a PW70A with one changed component...and I personally wouldn't trust it as the rest of the circuit is only designed for about 70W
    Garry
    www.aimee.cc
    Aug 1999
    Washington D.C.
    The OPUS 90 watt is designed for the ITX motherboards, and it will work fine for your purposes, unless you're running a lot of high current devices(3+ HDs). I'm selling them for $149.99 from the www.mp3car.com/store Same price as direct from OPUS without the hassle or wait!
    Jan 2004
    State College, PA
    I think I'll bite the bullet and go with the 90 Watt Opus (Zip-Lock, thanks for the suggestion). I had a mildly sketchy feeling about the PW120A, but since I had the hot finger and bought it already, I'll probably just re-sell it on ebay. Lets hear it for a lesson learned the (slightly) hard way
  1. Shuttle XPC or Via Epia m10000???
    By RaZor in forum General Hardware Discussion
    Last Post: 06-04-2004, 11:35 PM
  2. VIA EPIA MII 10000 vs. M 10000
    By imprezive one in forum General Hardware Discussion
    Last Post: 03-02-2004, 10:17 PM
  3. Will this VIA EPIA M10000 setup work properly??
    By b5b4you2 in forum General Hardware Discussion
    Last Post: 01-20-2004, 10:12 PM
  4. v10000 epia vs m10000 epia
    By traitorhound in forum Newbie
    Last Post: 11-27-2003, 10:19 AM
  5. Fore Sale- EPIA M10000 in case-all complete!
    By bradaland in forum Classified Archive
    Last Post: 11-27-2003, 09:09 AM
