Page 1 of 7 1234567 LastLast
Results 1 to 10 of 64
Thread: 7-16Vin 12Vout 6A Iout regulator plans
    Dec 2003
    Based on 4 PT5071 chips (texas instruments) it requires 2 A type and 2 N type.
    it only requires 8 other caps and 8 diodes, 2 connectors and whatever board and enclosure you use..
    feel free to modify as you wish just gimme credit for the designs..
    the caps i used are NTE NEV100M50DD 50v 100uf electrolytic caps
    the diodes i used are LN5404 (big bastards but they can take the power)
    i used some little green connectors i picked up at active, 0.3" lead spacing or something..
    you may want to clean up the layout a bit before etching it, there are some traces that are pretty close together and caused me some troubles. here's the component layout, schematic and PCB design that i came up with..
    good luck and have fun. this has been tested for use with a PW70a and so far so good.
    SURVIVES CRANKING no problem.
    Happy soldering, Ry.
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    hi I have some questions relating your dc converter
    - how much money did you approx spend to build it ( components )
    - is it easy to get the components ?
    -can you post a pic on the whole mounted ? ( photo)
    sorry english is not my native language - what did you mean by <<SURVIVES CRANKING no problem.>> Did you meen no reboot ?
    many thanks
    Félix
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    Dec 2003
    Update, heh, just finished testing and for some strange reason the regulator closest to Vout gets super toasty...
    all my diodes seem to be fine (thought i might have blown one up soldering) and there aren't any bridged or connections as far as i can see..
    it's weird, they get warmer as they get closer to the Vout side of the board.. R1 is barely warm, R2 is noticeably warm, R3 is pretty warm and R4 is burning hot
    needless to say i killed the power as soon as i saw this but i don't have any test equipment (like a scope or a function generator or even a decent 12v power supply or anything.. just a cheap radio shack multimeter) to figure out where the problem is...
    if anyone builds one of these PLEASE lemme know what happens and definetly consider these plans a prerelease version
    Good luck
    Ry
    Dec 2003
    the best way to get components for this kind of thing is order samples from TI, that's how i did it (i live in canada and i still got them less than 3 days after i ordered them)..
    just order one of each package type (the PT5071N and the PT5071A) one day and then go back the next day and order another pair, that's the 4 that you'll be using.
    the other components are VERY standard, the diodes are really standard and i believe it's possible to use anything from LN5401 to LN5409... (not sure on that tho) and the caps may be the problem with it overheating so don't take my word for it..
    and yes, it survives cranking/starting the engine without rebooting or even twitching one microvolt.
    again, there are still unresolved bugs with this design. i don't reccomend building it with my specs until someone fixes it and tests it.
    Raw Wave
    Jun 2003
    Nice idea
    But how much is the total cost if you were to buy?
    Dec 2003
    budgetary pricing on the PT5071s is $21.20 at 1000 units, that's what their website says
    i have no idea how much they'd be from distributors or even who would carry them.
    Dec 2003
    boost-buck 12v regulation for a PW-70a
    here's the thread that i pulled the designs from (and modified highly)
    Feb 2004
    Jyvaskyla, FINLAND
    Hi !
    I live in Finland and I got samples from TI in 3 days - thats pretty cool ! Now I plan to build the regulator using three PT5071s, but I'm wondering if it would be enough to use only two capacitors(maybe some higher quality tantalum type) - one on input and one on output. What do you think ? Have someone tested that configuration ?
    Apr 2002
    Houston, TX
    Hey Greenwire,
    I am confused on what the diodes are for? Do they prevent the (4) units from feeding back on each other? Do they keep the output balanced?
    I didn't see any use of diodes on the TI spec sheet for the Vin and Vout lines, so that is what makes me think the above reasons.
    But all in all a nice idea and I will lt you know if the Regs get hot for me two when I get it built.
    Dec 2003
    dug1697: the diodes are schottkey diodes that isolate the chips' outputs from each other, the diodes ONLY isolate the outputs, the inputs are not isolated (only filtered by the caps). that second diode (the one to ground) is to bring the chip's voltage sensing up to a level that will compensate for the voltage drop across the other diode so you still get 12Vout.
    pajka: i've been told that with each diode there's a potential for 500mV of noise, that's why a diode on each chip is necessary
    i figured out what was happening with my PCBs. the impedance of the copper was adding up along the caps and because of that the chips saw more and more impedance on the input lines from the top of the board to the bottom..
    i'm working on a new PCB right now but if ANYONE knows **** about analog PCB design any help or constructive smacks-to-the-jaw would be greatly appreciated.
