Nokia,
I am about to order the same package, as it works out over $100 cheaper than buying the mobo and then an opus.
There should be absolutely no problem with the psu and ITPS if you use entirely
laptop components. The mobo does not have any use for the 12V, and laptop hdds and laptop cd/dvds only take
power from the 5V rail, as opposed to standard 3.5" hdds and 5.25" opticals which take a lot of power from the 12V rail. If you were using a 3.5" hdd you would probably find that during cranking (eg starting the car) the voltage could drop as low as 10V (or even worse) this would cause the hdd to stop working and thus the computer would crash.
Another point to note is that laptop drives are designed to be used on the go and so have better shock protection than standard desktop drives.
Hope this helps
