Results 11 to 20 of 23
Thread: Elimate inverter buzzing from your speakers
  1. #11
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    TruckinMP3,
    Sounds like your one of those guys who's pete pives is telling people to search rather than pointing them in the right direction. Get off your high horse
  2. #12
    Newbie bud_d's Avatar
    Feb 2004
    Minneapolis, MN
    do those dc to dc solutions work for laptop use?
    Quote Originally Posted by TruckinMP3
    That many posts might tell you (if you read them) that inverters are a second choice in power solutions. DC to DC is the prefered solution for ease of use, functions and lower noise.
  3. #13
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by bud_d
    Depends on the laptop. The DC solutions I have seen are targeted at desktop models. There may be others. The issue is really what your laptop requires for power.
    antimatter, did you figure that out on your own or read my sig file?
    Yes, I say search because most installs are different.
    That means the answer is different.
    Also, by searching and reading you might find something cool that will work in your install that you did not think to ask about.
    I bet you are one of those people that just make judgements on very small amounts of information..... see what I mean.
    Tons on info here, very few cookie cutter solutions. The closest in my opinion are:
    DC to DC OPUS ps
    and the indash one din VGA XENARC
    Lots of folks seem to be using the small VIA mainboards as well.
    Have fun
    TruckinMP3
    Read the FAQ!
  4. #14
    Jun 2002
    Malaysia
    That is bull.
    I've been using an inverter without any noise WHATSOEVER.
    Now that I've switched to DC-DC, I'm getting an engine noise.. whining.
    There is no metal on my plexi case. There's no way to ground my case.
    There is no doubt, inverters make the best choice for noiseless power supplies.
    THe only thing DC2DC has got going for it is the size of the installation
  5. #15
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by masch
    That is bull.
    Why'd you switch then? Are you switching back?
    Fabricator
  6. #16
    Jun 2002
    Colorado
    That is bull.
    You must be the only one.
    Did you make any changes to your grounding set up when you went to DC-DC?
    What inverter did you use that was noisless?
    I am sure the rest of the folks using inverters will enjoy your wisdom.
    TruckinMP3
    Read the FAQ!
  7. #17
    Feb 2004
    Colorado
    I'm using a coleman inverter for my setup and haven't had a problem with noise at all. there is none which is surprising considering I don't even have the case grounded. but I'm not complaining
  8. #18
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I tryed using a inverter as I'm using a PC, but a very small one, with a external psu.. this doesnt enable my to attach a opus.. so to start with i had one I payed 25 quid for from maplins.. this didnt work as the output from this is a square wave, and caused massive buzz through my speakers when on.. so then I bought a sine inverter.. this solved the buzz.. but I then gained a brick in the boot, also as my car is a estate the noise from the cooling fan was a mare.. so this went back.. I just bought a switchmode inverter.. this is a special made just for PC's it cost just over 60.. its very small no noise.. and it WORKS.. its rated at 100w which is just enough for my dell. I got it from www.cpc.co.uk there website is also www.switchedmode.com the unit I used was product number sm2911. It has a 12v lighter on one end, and a IEC kettle socket on the other.. they also do the clover plug ones and the figure8 ones.. Awesome for those of us where DC-DC isnt a option
    CdR
  9. #19
    Jun 2002
    Malaysia
    I switched because of the size of the setup. An inverter is like another brick to be placed behind the dash. The DC2DC solves this issue, but I didnt know what people were talking about (noise) till it was installed.
    Anyway, it wasnt really noise, I think its more of hearing the high frequency engine whine.. its directly proportional to the RPM.
    I didnt ground anything with the inverter and with the DC2DC. How do you ground a mobo in plexy? connect the screws or what? If only I can simulate the environment at home then I may find out what's the reason of the whining. In the car with the cramped spaces its much harder.
    My inverter was 300W from Maplin Electronics. It ran a little hot so I had to take off the top and put a cooling fan on it.
  10. #20
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    "Please Mr Mp3 man Spoon feed me the info"
    search on inverter and buzz, second hit.
    Inverter / FM Modulator / Buzz
    Actually, I agree with creating a sticky. Instead of sending the poor hapless dudes (and we all know by now that we are ALL dudes) on a crazy search from which there is no return, let's put stickies up for the oft-covered topics so that the new posts will be more likely to be about something from which we can learn.
    I understand that posts of the same questions over and over can be tedious and trying, but for pete's sake, that's what the stickies are for, ne?
    Just my two cent's worth.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  3. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 08:19 AM
  4. inverter buzzing
    By brandondere in forum General Hardware Discussion
    Last Post: 06-09-2001, 06:06 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
