Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Elimate inverter buzzing from your speakers
  1. #21
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Works for me...
    TruckinMP3
    Read the FAQ!
  2. #22
    Jun 2002
    Malaysia
    so anyone figured out how to ground an epia in plexi?
  3. #23
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Most likely the best way would be to install a metal panel that the board itself mounts to, then attach a grounding line from that panel (grounding plane) to your car's chassis. This will be the most effective way to ground your board and help eliminate buzz.
    Your desktop doesn't buzz because the whole case is a grounding element, and the power noise actually finds its way back through the power supply and back to your house's grounding setup.
    In a plexi case in a car with no grounding connections, there is no place for that excess power bleed to go, so you have to bleed it to the car's body/frame instead, which is how the manufacturer keeps your stock stereo from buzzing so badly.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  3. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 07:19 AM
  4. inverter buzzing
    By brandondere in forum General Hardware Discussion
    Last Post: 06-09-2001, 05:06 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
