Great working tank circuit with backup bat.
Quote:
Originally Posted by LESLIEx317537
The voltage is the same for both batts, so you will not need a voltage regulator.
You should place the diode right before the backup battery so the current doesn't flow backwards and try to crank the engine with the backup battery.
Now this was my great idea I came up with last night after thinking about this tank thingy for 1 week..............................
Since you only want the battery to charge when the PC is on, since we have no way of shutting off the charging cycle, you need the PC on to draw some juice away from the abttery do it doesn't overcharge.
Yo accomplish this, you basically wire a relay and hook it up to a molex so it connects the backup battery only when the PC is powered on and the 12 volt line on the molex is throwing out 12 volts.
Now this solves issues such as the accesory cuttingout during crank, the molex 12 wont cutoff during crank leaving teh relay connecting hte backup battery and wa la. No reboot. Well if I planned it right, I hope. :)
Does that make sense? I'm suprised no one ran the relay turn-on from the PC PS 12 volt Molex. I love my great ideas. :):):)
OK I tried this out and it works awsome, I put a relay on the accessory wire to cut the power from the battery to the inverter when the accessory wire is powered off and I put a second relay switched from the 12volt wire on the hard drive power plug to keep the back up bat from recieving power when the computer is not turned on. This should keep the Back up from not over charging since it only get charged while the computer is pulling volts. And if I forget to turn off the computer it will run off the backup until it is totally drained(which is ok since the backup is a NICd anyway). Should work with a rechargable lead acid battery as well. I found one a rat Shack for $28.00 today. 12v 5ah, great for this use.
Thanks again for the help. :D :D :D ;) :cool:
