Results 1 to 5 of 5
Thread: ATX, ITX DC-DC Power Supply
    Mar 2004
    Knoxville
    This may seem like a dumb question but will an Opus DC-DC ATX power supply work with an ITX form factor? I am purchasing an Epia M10000 motherboard and need to know if this power supply will work with it. I also noticed that there are many different wattage variations you can purchase. I saw 60, 90, and 150. I plan on running HD, memory, USB Linksys, Internal DVD player, and possibly a USB GPS receiver. Which power supply would be best for what I need. I don't want to buy to much power because of cost...
    I also need a controller with the power supply if I want the start up and shut down feature correct? Thanks for you help!
    Aug 2003
    Lancaster, PA
    Yes, mini-ITX and ATX share the same wiring scheme. 90W should be fine, 60W is usually enough for a M10000N and a hard drive so you want a little extra to power the other stuff.
    Mar 2004
    Knoxville
    Does the OPUS 90 watt come with a built in controller or do I need to purchase the ITPS?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Did you do "ANY" reading bofore posting your questions?
    Yes it has a controller
    TruckinMP3
    Read the FAQ!
    Mar 2004
    Knoxville
    Thanks for the reply..... Sorry for not lookin first
  1. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  2. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
  3. What are the ATX DC to DC power supply options?
    Last Post: 07-08-2002, 05:25 PM
  4. DC ATX Power Supply Link
    By xa0s in forum General Hardware Discussion
    Last Post: 08-29-2000, 12:30 PM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 08:47 PM
