Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Ultimate System
    Mar 2004
    Ultimate System
    I've spent the past few weeks searching through this site trying to make sense of it all. I know enough about computers to be able to assemble one but not enough about power to understand a lot of this.
    Basicaly it seems like there are 3 criteria to choosing a system: Power, cost, and space.
    I only want to do this once and I want it to be capable of doing anything: OBD-II, DVDs, mp3s, mpgs, emulators. So price is no issue.
    I've been doing fiberglass for a while now and am confident I can work with any space. So lets assume space is no issue.
    I've got an optima redtop and am looking into upgrading to a higher output alternator. Although I'm not sure how yet... I'm running a pretty powerful audio system already with a 5 farad cap, 2 7" monitors, 1 10.4" (to be used for the computer), a gamecube, and a few little things here and there, so I don't want this computer to put me over the top on power consumption.
    Basically my minimum requirements are as follows:
    - at least 250 gig harddrive at 7200 rpm
    - at least p4 3.0 gHz
    - at least 4 USB ports
    - at least 1 firewire 800 port
    - at least 16x dvd
    - 2 slots that support up to 2.0 gb RAM
    - good sound (in the form of a video card or onboard, whichever)
    - good video (in the form of a video card or onboard, whichever)
    - I don't care if it comes on when my car does. I can boot it up mid drive and shut it down before I turn the car off. No biggie.
    Anyone want to help me out fullfilling this? It could mean getting your name in a mag.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Do your research. If you can build a PC, the topics you need are power and OBD-II.
    DC to DC power, Get an OPUS as for OBD-II do more reading.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by dark_muppet
    - at least 16x dvd
    I am sorry, but a p4 3 gHz is a little overkill, especially if you are looking to cut down on power consumption, many if not most people here run 1ghz or less and have no problems. If you want small, and low power consumption, look into the VIA Epia M10000 boards,,
    My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
    Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    You can have it cheap, you can have it fast, or you can have it small. Pick any two. Looks like you tossed out "cheap" so you should be good to go.
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    Newbie SavageKabbage's Avatar
    Jan 2004
    Quote Originally Posted by TruckinMP3
    The setup he wants will probably be too much for the Opus. Expecially if he wants HT which draws more power, I'm going with a 3.0+ HT myself.
    Quote Originally Posted by MeanGT
    Looks like he wants a top of the line system. I know I don't want anything less than a P4 2.4 HT. Once my setup is done i'm going to be controlling 3-4 different monitors, all showing different things, via two dual head video cards. I guess it really depends on what he wants do do with the PC.
    Jun 2002
    Colorado
    Quote Originally Posted by SavageKabbage
    Sure, he is still in the do more reading situation...
    TruckinMP3
    Read the FAQ!
    Mar 2004
    More guidance:
    Yes. The goal of this system is to have a top of the line computer able to ultimately do anything. I want to be able to keep this in there for as long as I own the car without having to worry about upgrades or speed. There will be some games that could be played on it so speed is an issue. All will go to just one monitor though.
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    woah
    Dang...you must do alot of parking to make all that Car PC worth while
    Mar 2003
    AZ
    Quote Originally Posted by stimps
    I'm gonna go out on a limb and say that parking = shows.
    *edit: wow, I must be postwhorin' it up today...i didn't know this board had flood control! Hah! "the administrator has specified that you can only be helpful once every 60 seconds *
    Mar 2004
    i run a 3.2 Gig HT P4 with a shuttle 65G2 black case - ill cover my build in alcantara this week, and hopefully post some photos.
    i use an OPUS PSU. you want one.
    you may have issues with power, as youre going to be running more ram, more USB devices etc etc..... mine works fine, and i calculate that i use around 150W of the 150W PSU - you may just have to buy it and prey.
    basically, all im saying is it should be quite possilble. Th ePC will only drain about 15A max. your screens will be drawing 2-3 amps MAX - realistically the PC screens etc... dont consume much power.
    its the amps driving the audio in a large system that zap the ccurrent.
    HTH
    Stu
  1. Replies: 9
    Last Post: 02-28-2004, 10:51 AM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  4. Do I have HU or not? -- Factory Audio system
    By helloman in forum General Hardware Discussion
    Last Post: 03-06-2001, 04:11 AM
  5. Arise ACE-865V dc-dc ps, system wont post, help...
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-17-2000, 03:08 AM
