Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: regulating morex 60w psu
    Sep 2003
    Finland
    I have morex 60w psu and (like we all know) it doesn't regulate 12v output, so I thought something like this:
    Maybe I just regulate the 12v output? (put PT5071 between psu and motherboard atx-connector)
    Would this work? Only problem I can think is that if psu can't handle ~14V that my alternator puts out.
    Has anybody tried this?
    Edit:
    This way you would need only 1 PT5071, not 4 of them... and I believe it would survive cranking...
    Mar 2004
    Quote Originally Posted by vvog
    i was just asking about that too... regulating 12V on a non-regulating PSU... be interested for sure!
    Low Bitrate SportivoWISH's Avatar
    Jan 2004
    Singapore
    Edit:
    The Morex PSU takes in 11.6-12.6VDC. Which means your regulator needs to be inbetween the Battery and PSU, else your PSU will fry sooner than expected.
    I tried out using GingerPrince's 12VDC Regulator diagram and it has been working well regulating 14.6VDC 4.6A to 12VDC output.
    Have fun
    MediaCar
    Girder with Igor plugin
    EPIA-ME6000 w 256MB DDR
    Morex 55W PSU
    12VDC Regulator
    IBM DJSA-220 20GB
    90% completed in a plastic case (8"x10"x2.5")
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by SportivoWISH
    Have fun
    You probably will find this interesing http://www.idotpc.com/TheStore/Perip...ct.status=blue
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Sep 2003
    Finland
    Quote Originally Posted by Bravellir
    Brave
    Thanks for the link, Brave!
    I'm building similar regulator to my psu.
    Specs on that dc/dc-board @IDOTpc.com are same as the normal morex 60w.
    So I guess morex psu will survive car battery output.(10V-15V)
    Specs for regulator @IDOTpc.com:
    Input Voltages Required (V): DC 11.0 ~ 15.5
    Output Voltage (V): DC 12.0 (+/- 5%)
    Output Current (A): 1.5A
    Peak Current (A): 2.0A
    So it only regulates psu's 12V output(1.5A, 1 PT5071 regulator can be used.) http://focus.ti.com/lit/ds/symlink/pt5071.pdf
    I have done some testing with fluke and I think I know where to put the regulator. (not going to put it after psu as mentioned in first post.)
    Sep 2003
    Finland
    Regulator completed! :)
    I completed building the regulator.
    So far I have tested it with mascot 5-15v power supply. Computer boots without problems @ 9-15V input voltage. I even tried to lower the supply voltage to <7V when computer was on, no effect!(only mascot started to make some noise, because current draw was too much i guess)
    Output voltages (12, 5, 3.3, -12) were perfect at the test time.
    I post some pictures when I have my camera with me.
    Dec 2003
    Porto, Portugal
    please do
    Status -->
    BraveCar 2.5
    Sep 2003
    Finland
    Ok. here's link to the pictures: link
    Jun 2002
    Malaysia
    vvog, parts list? and also which pins on the regulator did those wires connect to? (schematic like pin 5 - regulator output etc)
    Jun 2002
    Malaysia
    I noticed you copied some of the design from the ipod site, but how do you know where to cut on the morex for the unregulated +12 in and regulated +12 out?
    And how did you figure out the 2 capacitor sizes (I noticed one of them is 100uM) but what's M?
    And white Axicom chip, whats that for?
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. morex psu noise fix
    By starfox in forum Power Supplies
    Last Post: 03-15-2004, 08:19 PM
  3. EPIA rebooting! morex 60W and MSI bluetooth dongle?
    By masch in forum General Hardware Discussion
    Last Post: 03-11-2004, 04:08 AM
  4. Replies: 8
    Last Post: 06-12-2003, 04:58 AM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
