Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: How to install Diodes
    Jan 2004
    Silver Spring, MD
    I picked up a diode from Radio Smack the other day so I could wire it to prevent backflow of power. This thing is a LOT smaller than I thought it was. What is the best way to wire it in? Can it only be saudered? It's so small, I'm afraid to break the little thing. What have you guys done to wire yours in?
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    methinks you got the wrong diode.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Maximum Bitrate none's Avatar
    Sep 2003
    What are you using this diode for?
    As the wiz sez, you need to make sure your diode can handle the power. Being small, it might not be able to handle much.
    Yes, soldering is the way to go.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    is your diode black with a silver stripe? or clearish looking red (germanium..oops). If it is the black one, it will have polarity instructions on the back, and if it is small you probably will need to parallel a ton of them to get them to hadle the kind of amperage that we are dealing with or you may let the smoke out of the box
    http://www.kpsec.freeuk.com/components/diode.htm
    2005 Ford Focus ST
    Jan 2004
    Silver Spring, MD
    The diode is small, but it's the same one (1N4001) suggested in this thread. You guys think it's not enough? Am I missing something?
    Quote Originally Posted by gospeed.racer
    Sep 2003
    Quote Originally Posted by Norrin302
    FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    I will try to not make a comment that will get me into another flame war, but some people in that thread do not know what they are talking about. If you are building a tank circuit for a car PC, you need a bigger diode.
    Jan 2004
    Silver Spring, MD
    Alright, so which diode would you suggest and why?
    Quote Originally Posted by none
    Sep 2003
    One that handles enough amps. What answer do you want for why?
    You still haven't specified what it is for, is it a tank circuit? If so, disregard most everything in that thread and do some searching in the Power Supply subforum.
    Jan 2004
    Silver Spring, MD
    I buoght the 12VDC 5.1Ah Nickel Cadium recharable battery from TheSpecialist for my ITPS to allow it to survive a crank. I'm running the ITPS to a PW70a attached to an EPIA M10000. How many amps do you think the diode would need to handle for my setup? I appreciate the help, I'm still learning..
    Feb 2004
    Australia/Norway
    I have the exact same setup and it is working perfectly.
    I am using a 1n4004 diode on my tank circut and it does survive cranks.
    The main battery drops bellow 8v but the second battery keeps a constant 13v while I crank the car.. No problem at all. I am also using a ITPS but not for what it is supposed to be used for (shutdown controller)
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  2. NewB Questions for Laptop Install
    By PaulDePimp in forum Newbie
    Last Post: 02-09-2004, 10:57 PM
  3. How to install 98lite?
    By ugosplat in forum Software & Software Development
    Last Post: 07-27-2003, 05:40 AM
  4. Inverter install help
    By JoeCool in forum Power Supplies
    Last Post: 04-17-2002, 05:53 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
