Can you adjust shutdown voltage on Opus 150w?
Well, the power supplies from I-Tuner I can't say much about... but they aren't working. So now I need a REAL supply.
Is the 'low battery shutdown voltage' adjustable on the Opus 150 Watt SFX DC-DC Vehicle Power Supply for ATX?
According to the stats, it's 11v +/- 0.75v
I'll be using it in a car that already has an auxiliary deep-cycle battery, it's solenoid linked to the car battery when ignition on, and stand-alone when ignition off... so I can drain this aux battery flat, and the car will still start. When the ignition is off and it has a computer load, it might only show 11.5 volts (freshly charged from AC even), this would be under shutdown voltage according to the specifications for the 150w.
I would want to adjust this to the small end... no shutdown until 10.25 volts, is this possible?
Then again, it would still run at under the low voltage shutdown level ( 7 - 10.25V) for up to an hour (if changed from factory default of 10 secs), right?
http://www.visualecho.org/carputer/guts.jpg
