Results 1 to 5 of 5
Thread: Can you adjust shutdown voltage on Opus 150w?
    Newbie Visual Echo's Avatar
    Feb 2004
    Ann Arbor, Michigan
    Question Can you adjust shutdown voltage on Opus 150w?
    Well, the power supplies from I-Tuner I can't say much about... but they aren't working. So now I need a REAL supply.
    Is the 'low battery shutdown voltage' adjustable on the Opus 150 Watt SFX DC-DC Vehicle Power Supply for ATX?
    According to the stats, it's 11v +/- 0.75v
    I'll be using it in a car that already has an auxiliary deep-cycle battery, it's solenoid linked to the car battery when ignition on, and stand-alone when ignition off... so I can drain this aux battery flat, and the car will still start. When the ignition is off and it has a computer load, it might only show 11.5 volts (freshly charged from AC even), this would be under shutdown voltage according to the specifications for the 150w.
    I would want to adjust this to the small end... no shutdown until 10.25 volts, is this possible?
    Then again, it would still run at under the low voltage shutdown level ( 7 - 10.25V) for up to an hour (if changed from factory default of 10 secs), right?
    http://www.visualecho.org/carputer/guts.jpg
    Feb 2004
    Ann Arbor, Michigan
    bump
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    This would be best directed at Kris from Opus. I don't belive there is any way to do what you are looking to do, but Kris would certainly know more.
    Aug 1999
    Washington D.C.
    The OPUS shutsdown at ~10.9 volts after 1 min. It would require a change in the microprocessor code to accommodate your request of changing that value. You can get that changed if you order in quantity about 100 units, otherwise it’s not something that you can change yourself.
    Feb 2004
    Ann Arbor, Michigan
    Thank you! I was hoping I could just change a resistor or zener diode, but I will have to risk it.
  1. Closed - Possible Opus Group Buy
    By BoraXP in forum Classified Archive
    Last Post: 05-18-2004, 11:03 AM
  2. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 03:21 AM
  3. Does the Opus 150W have an ATX12V connector?
    By shchua in forum Power Supplies
    Last Post: 11-30-2003, 09:54 AM
  4. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
  5. Older OPUS 150w /w EPIA-M mod?
    By GTC in forum Power Supplies
    Last Post: 09-19-2003, 03:54 PM
