Results 1 to 10 of 10
Thread: How to power the PC OUTSIDE the car?
    Mar 2003
    Cary, NC
    Hello,
    Wondering what the best way to power a DC-DC powered car pc is when its not in the car? Do you unhook everything, and then use a AC-DC PS inside the home? Or is their a better way to handle this, maybe with AC-DC converter?
    Thanks,
    Mark
    Variable Bitrate Ashlawn Kemling's Avatar
    Feb 2001
    Williamsport, PA
    Like you have the power blocks for laptops. Same idea.
    Mar 2003
    Cary, NC
    Quote Originally Posted by Ashlawn Kemling
    Thank you,
    Which type of plug does the Opus 150 and 90W PS take, and is there a favorite converter people are using inside the home?
    Thanks,
    Mark
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Currently I have inverter setup in the car, but soon to be replace with sproggy DC-DC PSU. My Mastero/Sproggy 3.0 can't handle the hardrive. Once I have DC-DC PSU, I just use AC-DC PSU inside the house. It's not that complicated and only 2 connections to plug and unplug.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    well you only really need to unplug the atx connector and hard drive.. and parhaps a cd/dvd/cdr whatever drive if you have it. so a normal atx supply should be quite the best route to go
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    If you are using an Opus, you chould just disconnect the ATX P1 connector from the Opus then put a gender changer on you AC-DC power supply, then hook up your AC-DC with gender changer to the ATX P1. That way you only need to unhook the one power plug.
    Constant Bitrate parawing742's Avatar
    Jun 2003
    Tennessee
    What about an AC-to-DC converter like this: http://www.tripplite.com/products/in...ed_dcpower.cfm
    Would these get the job done to run an Opus supply? How many amps does the Opus need to run?
    Phillip Hullquist
    I entertain people through adventure movies.
    www.11visions.com
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    Uh, well... power = voltage x current... so 90watts / 12 volts = 7.5 amps. It's not so hard to just swap out the power supply though.
    Oct 2003
    Toronto, Canada
    For 150W Opus:
    AC to DC Supply
    120V Input
    12~15 Output
    10~12.5 Amps
    Right?
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Aug 2003
    While my box is not in the car, I use the AC-DC power adapter that came with the case (morex cubid 2677R) which provides +12V DC:
    I replaced the existing female power plug and wiring with a new plug wired to the Opus. I then added another female power plug for the remote turn-on signal. I added an SPST switch with a diode to override the remote turn-on signal. When I bring the box inside, I simply connect it to the AC-DC power adapter and flip the switch.
    Code:
      O  +12V         O  head unit   .----------.
      |               |              | DC-PS    |
      |               o--------------o Remote   |
      |               |              | Turn-on  |
      |               \  switch      |          |
      |                \ SPST        |          |
      '---------------o--------------o Vin      |
  1. PC To Car Speakers
    By eCar™ in forum General Hardware Discussion
    Last Post: 08-17-2008, 01:35 PM
  2. Replies: 6
    Last Post: 08-22-2005, 02:10 AM
  3. Need some advice? CAR PC Short Life
    By bklynkaos in forum General Hardware Discussion
    Last Post: 02-26-2004, 05:41 PM
  4. Experienced PC guys needs Car Audio Primer
    By SwapMeet in forum Newbie
    Last Post: 02-10-2004, 05:33 PM
  5. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 11:39 AM
