Results 1 to 7 of 7
Thread: Those of us with fussy inverters...
    Oct 2003
    I envy you guys that can crank the engine with the PC still running. The problem I have is that the battery voltage drops just enough to trigger the low-voltage shutdown circuit. I haven'y found any way to adjust or disable this threshold, and it cost me 120
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have found that if I have been running the PC for a while with the engine off, and try and crank with the lights on it cuts out, but I have learnt. and always make the lights are off when i crank.
    Yes I said crank with a C not a W
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    My inverter won't cut out when cranking, but it will sound it's "fault" alarm. The damn thing is so annoying. My opus was worth the money.
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    2nd battery
    This is why I installed a 2nd battery with a isolator so when I crank the motorcar, the starter does not pull any nice juice from the inverter battery and
    my cpu does not get effected in any way.
    Quote Originally Posted by Cherub211
    Feb 2004
    Orlando, FL
    What kind of inverter are you running?
    Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
    Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
    Nov 2002
    inverter
    Im running some 300 watt Walmart Inverter.
    Dec 2003
    ATL GA
    I don't have any of these problems. I'm using a Radio Shack invertor, similar to this one, but not exactly the same (mine's smaller):
    http://www.radioshack.com/product.as...%5Fid=22%2D146
    Eventually, I'd like to go with a dual battery, just to be safe.
  1. New Xenarc Displays/dimmable inverters
    By Whaleboy in forum LCD/Display
    Last Post: 01-27-2004, 11:01 PM
  2. Inverters - what to look for?
    By noodles in forum Power Supplies
    Last Post: 09-27-2003, 11:30 PM
  3. wanted a couple of low price inverters...
    By ewood in forum Power Supplies
    Last Post: 07-29-2002, 12:06 AM
  4. Inverters: I think this'll work, but checking nehow!
    By SensitivePsycho in forum Power Supplies
    Last Post: 12-15-2001, 02:57 PM
  5. Deals on inverters... Which one to get?
    By ncfoster in forum General Hardware Discussion
    Last Post: 12-29-1999, 05:10 PM
