Originally Posted by
wonderworm
Anyone know how important the polarity thing is on AC outlets? I've always gotten confused how to tell which way to plug in power cords for TV's, Radios, Computers, etc to make sure the positive and negative are in the right location and not reversed. Sometimes one slot will be a little longer than the other, but other times it is hard to tell.
Honestly, I think you can plug in all the above products and not have an issue even if you plug it in backwards. Many times it's impossible to tell unless you have a third grounding plug to be sure it's correct.
Well, I have 2 power inverters, a 300 watt and a 400watt. I had my carputer plugged into it as well as the ac adaptor for the LCD monitor. The monitor had no ground wire and I could only plug it in one direction due to physical limitations. However, I'm thinking now that the monitor AC adaptor was plugged into the Inverter in reverse and now I get the "Fault" light when I try to plug anything into the inverter. By plugging in the AC adaptor in reverse, I'm worried I ruined the Inverter.
Anyone know if I fried the inverter permanently? The fuses in the inverter are not blown, I thought they would blow first if I hooked it up wrong but maybe not. I also opened up the 400watt inverter and couldn't see or smell anything out of the ordinary. Unfortunately, I don't have a voltometer.
Any EE's out there to help me out?
