Results 1 to 4 of 4
Thread: ITPS Issues? or something else?
    _
    Mar 2004
    Little Elm, Texas
    Ok, I'm going to try to describe my problem, but it's kinda complicated...lol
    So I've installed the following:
    XP Pro
    Mini-ITX M10000
    Full size HD (5400rpm/160GB)
    full size slot load DVD player
    other misc stuff
    I am running the PW-70A and the ITPS. This is actually my second set of both units right now.
    Being that I compete in car stereo in SQ it's imperitive that this system work on a regular basis...which is one reason that this is so very frustrating for me right now.
    I get up this morning and turn the car on in order to try and get a few more hours of playing time on the Rainbow pro seperates that I just purchased before the show today in town. I vacuum out the car, leave the car running, drive around a bit, and everything works fine. My boyfriend and I go to Arbys for lunch before we head over to the show but when I get back in the car is when I start having new issues.
    It will go through the boot-up procedure just fine, untill my background and icons start to show up. I can see my background and all of my icons, I can even move around on the screen via touch (it's a VGA touch screen). BUT.....the task bar pops up but without any icons on it...it stays visable, only where the icons should be (start button and quick start icons and things in the sys tray) is cleared to the background....if that makes any sense.
    After trying to open a few icons the mobo beeps at me then the computer locks up. Restarting doesn't solve the problem. Then we checked the voltage into and out of the ITPS....13 - 13.5V in and 11- 11.5 out...hrmmmm....ok so we bypass the ITPS....now we're reading a constant 12ish in.....yet it still does the same thing on boot-up.
    Is this a software issue or is this a power supply issue?
    I know that windows will do funny things when it's not getting the right amount of power...either too much or too little.
    any ideas?
    Jan Bennett
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Red GTi VR6
    XP Pro
    Mini-ITX M10000
    other misc stuff
    any ideas?
    Well, the easy way to check, would be to plug in a regular ATX PSU, and see if you get the same problems...
    Mar 2004
    sounds like an explorer.exe issue. The shell isn't loading properly for some reason. That's why I'm planning on using Litestep (http://www.litestep.net/) when I setup my system. It's a pain to configure if you're not a computer person, but it uses less resources, is completely customizable, and doesn't tend to screw up as much as explorer.
    _
    Mar 2004
    Little Elm, Texas
    so....plugged in the other power supply andran it form the house...still doe the same thing....which leads me to believe that it's a software issue?
    now...how do I go about uninstalling windows when I can't even get into windows?
    lol
    Jan Bennett
  1. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 12:24 PM
  2. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 05:07 AM
  3. Yet another stupid newbie question (ITPS)
    By Nokia6600 in forum Newbie
    Last Post: 03-19-2004, 04:43 AM
  4. ITPS and PW-70: What turns it on?
    By dug1967 in forum Power Supplies
    Last Post: 02-15-2004, 08:22 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
