Results 1 to 8 of 8
Thread: Low battery Cutoff Voltage ??
    FLAC Mastero's Avatar
    Aug 2001
    India
    What according to all Should be the Low voltage cut off Volt be ..?
    a) 11.0vdc
    b) 10.5vdc
    c) 10.0vdc
    Please give your opinion.
    Mastero
    Low Bitrate mscar's Avatar
    Oct 2003
    Portugal
    for me 10.0 vdc will do.
    :: MSCAR ::
    .:: Multimedia System Car ::.
    Low Bitrate frenchnew's Avatar
    Mar 2004
    Canada
    Quote Originally Posted by Mastero
    a) 11.0vdc
    b) 10.5vdc
    c) 10.0vdc
    Mastero
    My vote goes to b) 10.5Volts
    frenchnew
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I go for 10.5. If adjustable, that is perfect.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    Absolutely ideal would be 2 stage
    9 volts for 1 second (for guys with weak battery's/ hungry starters) and 11 or so for normal so you don't drain the battery sitting in the parking lot.
    I realize that would be hard, but it would be ideal.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    I would say 10.5 is good for me
    Aug 2001
    India
    Thank you everyone for your time .
    Mastero
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    There are some applications where you would want the low voltage cutoff at 8v
    Think deep cycle battery, problem is most audio amps also have a cutoff voltage.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. Does your Opus's low voltage shut down function work?
    By cproaudio in forum Power Supplies
    Last Post: 12-19-2003, 08:24 AM
  4. Car battery voltage...
    By SkinnyBoy in forum General Hardware Discussion
    Last Post: 12-14-2001, 03:53 PM
  5. Minimum car battery voltage
    By Dima in forum General Hardware Discussion
    Last Post: 07-31-2000, 01:19 AM
