Results 1 to 10 of 20
Thread: help needed for backup battery Diode type
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    I've installed a 12v 2.2Ah back battery along with a 1N4001 Diode. When I used the carputer the diode overheated and melted. What size diode should I be using or was it just a faulty diode.
    May 2003
    MA
    Quote Originally Posted by bertybassett
    This is my info:
    Pw-70, ITPS, 12V 2.7Ah Battery, and the MBR3045 Diode.
    No problems so far (4months and counting)
    VWTronics
    FLAC Mastero's Avatar
    Aug 2001
    India
    MBR3045 or MBR6045
    Any Diode with at least 20+ Amps
    Mastero
    Sep 2003
    Gloucester (UK)
    should a diode get hot?
    Dec 2003
    ATL GA
    Yes, Diodes will get hot. They pass current, adding alittle bit of resistance to flow (alot of resistance in reverse). I don't know how much power your system draws, but you might try like a 1N4005. You might also need to look for a rectifier diode (same as a diode, just much larger). Radio Shack should have a large enough one.
    You could also go with a bridge rectifier, which is really 4 diodes in a square configuration. They're typically flat, and a heatsink can be mounted to some of them. Clip off the unused poles.
    Aug 2001
    India
    Yes depends how much power is passing through it ... MBR3045 shall require heatsink
    Mastero
    Sep 2003
    Gloucester (UK)
    so if I get a MBR3045 what type of heatsink should I use?
    Sep 2003
    Gloucester (UK)
    From the link below which one should I use.
    http://uk.farnell.com/jsp/search/sea...archbut=Search
    Dec 2003
    ATL GA
    I'd look for an old Pentium II Slot 1 style heatisnk and drill moutning holes in it. You can find them with fans if needed, but that should be large enough I'd think, cheap, and easy to find.
    Aug 2001
    India
    heatsink does not mean a major Big type a small To220 type will do the job ...
    Any will do .. (farnell link)
    Mastero
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  3. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Using a deep cycle battery?
    By nullity in forum Power Supplies
    Last Post: 02-08-2004, 08:42 PM
