Results 1 to 5 of 5
Thread: Using the carputer while the ignition is shut off?
    Mar 2004
    Madison, NJ
    Carputer & ignition switch
    Whenever I want to listen to the radio in my car while the engine isn't running I usually turn the ignition switch off (counter clockwise) to the position it was in before starting the car and then turn it another turn counter-clockwise. Are there any disadvantages to this method to power on the carputer when it's wired through the ignition switch while the engine is shut off?
    Mar 2004
    Madison, NJ
    Quote Originally Posted by XMfan
    I take it no one knows the answer to this one? I've searched this forum and couldn't find an exact answer. Perhaps someone could shed some light on this? Thanks!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    only that you run the risk of draining your battery.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    well what kind of car you have and how is the Ignition switch arrangement?
    By your description, it seem your lock is like this: LOCK/OFF - ACC - ON - START and you want to run the computer when the key is at ACC. The problem with this method is that your change of draining the battery, and the ACC circuit may not have power when the key is at START (cranking). If you use a shutdown controller, you won't have problem with connect to ACC circuit.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    So, if I understand correctly, you switch to ignition on but without the engine running?
    1) All electronics in the car will be active and drain quite a bit of power (since usually in this position, the alternator is providing power),
    2) If you have an old car with mechanical ignition interruptor, you have the risk of overloading the pulse transformer.
    As a solution to this problem, you could connect the shutdowncontroller to the ACC wire, or to the amplifier on/off line from the head-unit...
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  2. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  3. simple carputer setup
    By my97mitsgsx in forum Newbie
    Last Post: 02-08-2004, 11:25 AM
  4. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
  5. HELP!!! carputer reboots with ignition restart!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 05-31-2002, 02:11 PM
