Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: ITPS features when using an Invertor
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    Hi, i've decided to power my carPC off an invertor as DC-DC is expensive and pretty rare in the UK. Just wondering how i could control hibernate via the ignition ACC cable. Any other ideas on replacing what the ITPS would have done when using an invertor?
    Regards
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Nov 2003
    Seattle, WA, USA
    One thing you could do is to buy an ITPS (only $39) and have it drive a relay that turns on and off your inverter.
    The ITPS will turn the computer on and off with the ignition using the computers power button, and then power the inverter on and off at the right times.
    Feb 2004
    Ah hadnt thought of that, very good idea. Thanks
    Oct 2003
    Have searched the FAQ but can't find either a definition or explanation of what an ITPS is, can someone throw some light on this.
    Cheers
    Nov 2003
    Seattle, WA, USA
    Quote Originally Posted by sygad
    Cheers
    Here you go:
    http://store.ituner.com/ituner/itps.html
    There are lots of limitations with the ITPS, search for ITPS and you will see lots of debate/experiences. I use one, and I am quite happy with it.
    Jun 2003
    The problem with this is that the ITPS will send a signal to the computer to power on/off and also drive the relay to the inverter. When the computer recieves the signal to power on - the inverter has not started yet - relay adds delay then the delay for the inverter to start up. Is there a way to get around this? Possibly delaying the signal to the computer?
    Variable Bitrate wkolodny's Avatar
    DC
    Set your computer's BIOS to turn on when power is restored.
    Don't Fear The Gurkey
    Click here to check out My Setup
    Jun 2003
    You're a savoiur
    Jun 2003
    Crap - the bios thing did not work. Still same problem. How can you delay the poweron signal that goes to the motherboard by a slight amount - eg. 0.5 sec or even less???
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by alvins
    Funny, i just finish installing the ITPS and it just works fine.. no problem with the relay.. mayby you have a "slow" relay ?? mine its a vulgar automotive 30a relay
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  1. How to keep your invertor alive while cranking.
    By MiniRX7 in forum Power Supplies
    Last Post: 07-27-2005, 09:03 AM
  2. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 11:24 AM
  3. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 04:07 AM
  4. Help with Epia 800 / pw60 / ITPS
    By lalo in forum Power Supplies
    Last Post: 01-04-2004, 02:39 PM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 09:26 AM
