Results 1 to 2 of 2
Thread: voltage meter hack, maybe??
    IQ < 70
    Mar 2004
    i was looking at this to see if i could use it to cut the power supply.
    it says it has a voltage meter on it, and it has a temp regulator via fan control. if i could somehow get the volt meter hacked to a serial cable, then i could get the pc to shut down at a level that i choose, and do a soft shutdown, not a hard power cut. any thoughts, ideas, etc???
    Nov 2003
    Seattle, WA, USA
    This "PC Data Acquisition Unit" would be a simpler solution.
    .... but you miss out on the hacking part
    It gives you:
    Eight Digital Outputs. Open collector, 500mA, 33V max.
    Sixteen Digital Inputs. 20V max. Protection 1K in series, 5.1V zener to ground.
    Eleven Analog Inputs. 0-5V, 10 bit (5mV/step.)
    One Analog Output. 0.2.5V or 0-10V. 8 bit (20mV/step.)
    Small plastic box (140mm x 110mm x 35mm) with screen printed front & rear panels supplied.
    Connected to the PC by a 25 pin straight through cable.
    Software utilities & programming examples supplied.
    Seven pages of documentation plus schematic.
    Just use the Analog Input and a simple resistor voltage divider and you can measure any voltage you want.
    (CPS93 -- $64.95)
  1. Can you adjust shutdown voltage on Opus 150w?
    By Visual Echo in forum Power Supplies
    Last Post: 03-26-2004, 09:04 AM
  2. Boosting lineout voltage on SoundCard
    By alvins in forum General Hardware Discussion
    Last Post: 06-09-2003, 03:12 AM
  3. voltage divider to get higher voltage query...
    By THEMP3KID in forum Power Supplies
    Last Post: 09-23-2002, 08:34 AM
  4. Voltage Meter
    By Dima in forum General Hardware Discussion
    Last Post: 10-01-2001, 09:17 PM
  5. DC-DC psu and high capacity HDD
    By GrahamS in forum General Hardware Discussion
    Last Post: 12-19-1999, 06:44 PM
