Results 1 to 4 of 4
Thread: OPUS and/or Amplifier
    Low Bitrate cpjolicoeur's Avatar
    Boston, MA
    Question OPUS and/or Amplifier
    I have a few quesitons about the OPUS for a power supply.
    1) How do I hook the OPUS up to my car's battery supply? I know the OPUS will power my MoBo but where does the OPUS get it's power from (obviously the car battery, but how do you hook them up?).
    2) Instead of using an inverter or OPUS can I just use the a car stereo amplifier as a power supply since that is already drawing steady power straight from my battery?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    1) The same way you'll hook up an amp. Permanent 12V to the battery, ground to the chassis of the car, and the ignition wire to switched 12V
    2) No. Different things. However, you can use the same wiring from the battery to the trunk as the amps.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Boston, MA
    So, I will have to get some kind of wiring extensions to run the power wires from the OPUS under my passenger seat, up to the battery of my car?? I am still confused. When I look at the OPUS pics, it is just a circuit board with some Molex power connectors. Where are the cables for the OPUS to draw power from?
    Aug 1999
    Washington D.C.
    It comes with all cables you need to hook everything up. (ATX power out, Motherboard power switch, and 12v power input)
  1. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  2. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 03:21 AM
  3. Opus Group Buy
    By Skippman in forum Classified Archive
    Last Post: 09-18-2003, 01:50 AM
  4. fan directly pointed on an opus?
    By samc in forum Power Supplies
    Last Post: 08-21-2003, 09:36 PM
  5. Opus Power Limits
    By mhermann in forum Power Supplies
    Last Post: 05-23-2003, 07:06 PM
