Hes getting 13.9V in the the ITPS. That should be enough to put out a constant 12V.
Yes as rob said do measure the in and out voltages of the ITPS. If you do get a 12V out of the ITPS then it should work fine.
If you are still having problems I suspect the ITPS is having problems turning your PC on. Verify this by connecting a spare PC on/off button directly to the motherboard. See if you can turn on your PC on/off manually with the ITPS supplying the power.
LinkBack URL
About LinkBacks
