Results 1 to 9 of 9
Thread: random, rarely occuring shut-down problem (using opus 150w)
    Aug 2003
    Michigan
    being that my boot time sucks right now (very close to 2 minutes), i've encountered a strange, not too serious, but annoying problem with the opus:
    if i drive somewhere close enough that i get there before the system is fully booted, and turn off the car, the computer does not shut down like it is supposed to..
    further, if i then turn the car back on [PC is on the whole time], reboot the PC, and then turn the car off, after the 10-second timer expires the power is cut without the system actually shutting down properly.
    using XP.. and it works fine otherwise, i.e. i shut the car off while the system is fully booted/in media engine/etc etc etc
    i plan on cutting down the boot time in the not-so-distant future, and don't drive such short distances often, so its not a huge deal, but something i'm curious about.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    My solution to this problem, even though my boot time is less than 30 seconds, (sometimes you just want to move your car) is going to be an SPDT center off switch.
    One postion on the switch will disconnect the Opus' RMS line and keep the machine off, another position will connect the Opus' RMS to the constant 12v+ line and keep my machine on when I turn off the car and take out the key. The third position will just connect the Opus' RMS to the switched 12v+ in the car.
    Aug 2003
    Michigan
    not bad at all, i'll look into it. doesn't seem to be too difficult a solution either.
    except it still involves me going into the trunk
    VIA EPIA 533 MHz
    256 MB RAM
    20 gig HD
    Media Engine 2.1.4
    Newbie leon_id's Avatar
    Feb 2003
    #2 - same here
    sometimes I need to leave carPC running to copy music to it or install programs remotely sitting in house
    Leon
    Aug 1999
    Washington D.C.
    Iíve been in contact with OPUS Solutions about this issue. Future versions of the power supplies will have some sort of a minimum on time built into them. That way the operating system will have enough time to boot so the shutdown command can be properly handled.
    Aug 2003
    Michigan
    good deal, that'll be useful .. isn't there some sort of deep-discharge protection on the opus currently? how does that work?
    VIA EPIA 533 MHz
    256 MB RAM
    20 gig HD
    Media Engine 2.1.4
    Aug 1999
    Washington D.C.
    It shuts everything off at when the battery drops to 10.9 volts (after waiting for 10 seconds, so it won't shutdown during an engine crank).
    Feb 2004
    NYC
    What about hibernation? would that help you?
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Angry
    On a Opus 90w with the factory installed jumper inplace worked perfectly without your described problem. If i shut of the car before it booted up as soon as it got to windows it would immidiatly begin the shutdown problem. After i removed the factory installed jumper (leave standby power on) it wont even shut the powersupply off at all
  1. Closed - Possible Opus Group Buy
    By BoraXP in forum Classified Archive
    Last Post: 05-18-2004, 11:03 AM
  2. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 02:32 PM
  3. New OPUS 150w not working?
    By kylechughes in forum Power Supplies
    Last Post: 01-27-2004, 03:21 AM
  4. OPUS startup/shutdown controller problem...
    By rbarr110 in forum Power Supplies
    Last Post: 11-15-2003, 12:38 AM
  5. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
