Results 1 to 10 of 11
Thread: humming sounds coming from setup?! should i worry?
    Feb 2004
    hi all, i got my carputer installed a few days ago, but im having problems with power
    Im using a shuttle pc, connected to an invertor, which is linked into the ingition of the car via the fuse box. When the power its run like this, there is a loud humming sound from the PSU. Should i worry about it?
    The pc puts out about 300watts intotal, and the invertor is meant to be able to handle 300watt load with 600 peak.
    when the pc is connected to the mains power, its fine everything works (i think this is the same for when the invertor is powered directly from the battery).
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    You're just getting electrical noise. There are tons of threads started on this subject. Do a search and you will find multiple fixes.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    FLAC Mastero's Avatar
    Aug 2001
    India
    inverter should be always connected to the battery directly fused...
    Mastero
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    see, I was gonna say that, but he says its his power supply humming--not a humming sound from his speakers.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Did you try plugging in other things to the inverter ? I'd take it out if the PSU alone makes your inverter humm.
    Mine needs to be updated.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    As said above, make sure that your PSU doesn't hum when plugged into the mains. If it doesn't, do you have a square wave inverter (most 12V to 110/240V AC inverters are square wave as it's a lot easier to produce a square wave)?
    if you do, you might need to remove the AC RF filters and suppressor caps from the AC input stage.. Short out the inductors and desolder the capacitors. Be aware that you'll be fiddling with mains voltage circuits, so please be very very careful when you do this.
    Also, check if your inverter actually grounds the power supply. If you have a floating inverter (there's no ground pin on the output AC socket, or the ground pin isn't connected), you might need to ground the PSU enclosure to the negative car battery terminal / car chassis (if your head unit / amplifiers don't have floating line level inputs)
    Feb 2004
    hi, the pc works fine when plugged into the mains. Sadly i do not have a sqaure wave invertor, so i have no way of test this.
    Since the wires were installed professionally, im going to take it back to them and tell them the problem.
    What i have trouble understanding in the setup, is how they managed to install the invertor to the ingition, without connecting it directly to the battery? - I think they have just connected it to the fuse box under the steering wheel, with a 20 amp fuse or so.
    Im almost 100% sure that the invertor isnt getting enough power, and the PSU is humming because its trying to draw more power. I'll test something smaller connected to the invertor to see if i get any more wierd results.
    Do you think it worth buying a multimeter, and seeing how much voltage is being produced, also testing the amps?
    May 2002
    Australia
    You won't be able to measure the voltage and current coming out of the inverter without buying a mains measuring multimeter. Don't stick a normal lab multimeter across the mains voltage, you'll just fry the internal circuitry. Same with current, measuring AC current is very difficult, and measuring the current getting to your inverter is also going to be hard, as most multimeters won't be able to read 10+A for more than a few seconds.
    Ask them if they used a switched relay to power the inverter from the ignition. I hope they didn't connect the inverter to the accessory line
    Feb 2004
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=2211297650 - this is the item i bought, it uses enchanced square sin waves.
    From the tests i done i found out that theres about 12.2-14.8v going into the invertor, but going out is 240v. I believe the ampage is the problem here
    any good ideas on how it fix that?
    Feb 2004
    an update:
    I found out, no matter where i plug the invertor up to, it will only create 165volts, nothing more.
    Can anyone shed some light on this?
  1. awful sounds coming from my amp
    By cruzc_99 in forum Off Topic
    Last Post: 09-25-2001, 02:25 AM
