Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Inverter beeps when the engine is on
    Newbie JEzu's Avatar
    Jan 2004
    Hi everybody.
    This is my problem. A hace a 300W inverter connected directly to battery. On the other side there is a normal PC PIII with a 235 power supply.
    The PC works fine when the engine is but the the engine is on the inverter begin to beep and power off
    Any suggestion?
    PD: sorry for my english
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    not gettin enough juice
    Jan 2004
    How can I resolve it?
    Dec 2003
    not sure yet.
    dont know??? try shutting off everything that could be sucking some fo the juice. see what that does then go from there. what inverter are you using? what is its max. and min. input voltage? what vehicle are is it in?
    Jan 2004
    The car has everything off (radio, etc), only the engine is on. It's a Ford Fiesta 2002.
    Input Voltage of the inverter: 10-15 V
    Nominal power: 300 W
    Maximun power: 350 W
    May the power is from the power supply?
    Thanks for your quick answers
    Dec 2003
    not sure yet.
    yes that could be. your battery could be about dead. also depending on where you are gettin power from. is it connected directly to the battery? or some line you cut into?
    Jan 2004
    Directly to the battery. I thought about a dead battery too, but the problem happen only with the engine on :/
    Dec 2003
    not sure yet.
    alternator? what is your power supply unit for your computer? 300 watt? or less
    Jan 2004
    235 W power supply unit
    Alternator? it sounds to be a big problem...
    Dec 2003
    not sure yet.
    well the alternator is what recharges your battery. and if that is not fit then it will drain your battery and eventually lead to your engine being dead on the side of the road because battery is dead and can not get enough juice from alternator to keep running. Like I have found out with my past two vehicles(with no computer) :OP . No its no big problem just something to keep in mind. You can always take it in and test it if it is a major consern to you. I dont know what the problem with the inverter is. I get the same problem when I take my laptop/inveter with me in my mothers car, but it does not do it in mine. Also I have just gotten a new alternator. Im sorry im lost there... um I just bought these145 watt psu when i get them ill prob want to sell the other two. I dont know if that
    would be a reason why, just another to keep in mind. Sorry bro im at a loss right now. Any one else???
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 07:43 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  4. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 10:01 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
