Results 1 to 8 of 8
Thread: Power Supply Suggestion
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    Post Power Supply Suggestion
    I've been lurking about these forums for a couple of weeks now, searching through the various threads & researching some of the power solutions. So, I have searched on this subject. However, prior to finding this forum, I jumped the gun & started ordering items. Most of the items were well thought out, but the power unit definitely wasn't. So far, I have ordered the following:
    1) Via Epia M10000 1GHz (w/ Nehemiah Core)
    2) 512MB PC2100 DDR SDRAM
    3) 30GB 5400RPM 2.5" HDD (w/ USB 2.0 Enclosure)
    4) 8x External USB 2.0 Slimline DVD-Rom
    5) Lilliput 7" VGA Touchscreen
    6) Morex Car Power Regulator Kit
    Items 1-5 seem to me to be better good choices, but I have my doubts about the Morex Car Power Regulator Kit. Now as you can see from my sig, I have the kit listed for sale. This is the only item I am unsure of.
    This now leaves me with a little bit of an issue. Should I keep the Morex & ditch the regulator portion for an ITPS w/ Tank Circuit or go w/ an Opus supply? I see the Opus supplies are a bit pricey, but you get what you pay for. So, I ask the guru's of this forum for advice & thank you all in advance for any help you can toss my way.
    BTW: If this is in the wrong section, then I apologize in advance
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Opus rocks seriously. Less headaches after you FINALLY receive the product. I have only owned a Opus 150 and I could tell you I rarely had problems with it. Its pretty small also.
    Mine needs to be updated.
    Mar 2004
    New Windsor, NY
    Thanks for the input. Opus seems to be the way to go. I guess I shall see, assuming others give suggestions as well
    "I'm a dick!"
    Mar 2004
    All I can see about that morex is that it will not survive a crank since its min Vin is 11 volts. IMHO its a piece of crap go with OPUS, build one yourself but get rid of that one.
    Mar 2004
    New Windsor, NY
    Noted...Anyone else wanna throw in some advice?
    "I'm a dick!"
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    everyone will most likely say opus. inverter is bulky and link
    rob withey says some good stuff. and yes it is simple for inverter to work in house.
    Mar 2004
    New Windsor, NY
    That is definitely a good thread & I am so surprised I didn't run across it...Anyway, I think I have been swayed to the Opus Supply...I'll keep everyone updated when I get theis project underway
    BTW, thanks for all the input...
    "I'm a dick!"
    Dec 2003
    not sure yet.
    yup
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 12:48 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  4. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
