Page 10 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 91 to 100 of 198
Thread: Looking for a creative solution: USB bus still powered after CPU is off
  1. #91
    Mar 2004
    Vancouver, BC, Canada
    Quote Originally Posted by rando
    Yes, that's correct. Here's a schematic.
    I just did this mod to my OPUS 150 and I can confirm that it works as described with my EPIA M10000.
    Thanks again for the help Rando.
  2. #92
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by archimense
    N/P. BTW, you didn't actually mod anything on your Opus, right? I just bought an ATX cable extension and did my splicing there.
  3. #93
    Raw Wave
    Jun 2003
    Rando,
    Just out of interest...from what I suggested earlier on the thread was it really neccessary to have the delay between the ACC and trigger for the OPUS to work reliably?
    Im sure you mentioned somewhere that a delay may be needed from the result of your testing, or was it fine as it is?
  4. #94
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Ricky327
    Rando,
    Yes, I did confirm that the Opus intermittently failed to startup the computer when ACC is energized before the +12V input. See post #64 and your acknowledgement in post #65.
  5. #95
    Raw Wave
    Jun 2003
    Ah ok...I did remembered it being mentioned, sorry I cant be bothered to read all the thread again...its too long.
    Just made me wonder as I cant see any delay circuit on the schematic you posted...so I kinda assumed the delay was not needed.
    Those guys following your circuit may have reliabilty problems?
    or did I get it all confused now?
  6. #96
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Ricky327,
    Doing it the original way, using relays to drive the opus power would require a delay to give the +12V to the Opus before the ACC.
    The schematic is just using the relays to drive the PSON and +5VSB from between the Opus and the motherboard... which is not the way originally described.
    Does that help?
  7. #97
    Raw Wave
    Jun 2003
    Ah ok, thanks for the clarifications
    I should have followed the thread all the way...oh well.
    I think I better stay away from the thread as Im way out of line now
    Good luck
  8. #98
    Mar 2004
    Redondo Beach, CA
    @Ricky: It's a different solution.
    @savante: Correct!
    @Ricky: LOL, you're welcome here...everyone has a bad day now and then.
  9. #99
    Mar 2004
    Correct. I didn't mod the power supply itself, just the ATX cable from the OPUS to the motherboard.
  10. #100
    May 2004
    since I am no electronics expert, i've got a question about the schematic by Rando.
    Is it important which ground I take for the relay?
    Since it uses two +12v inputs, 1 from the ACC and one from the +12v of the opus, can I take any of the black wires used in the ATX connector or just ground it directly on the car? Or doesn't it matter?
    thanks!
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  4. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
