Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 101 to 110 of 198
Thread: Looking for a creative solution: USB bus still powered after CPU is off
  1. #101
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Ive thought about this myself. I think if you ground it to your car you would be ok. I would try to ground it to the same point you are grounding your opus...
    I think at that point you would have common ground, which would basically be the same as connecting it to one of the black molex wires. I could be wrong though....
    Just my thoughts.
  2. #102
    Mar 2004
    Vancouver, BC, Canada
    I don't think the ground should matter. For convienence though I used the ground wire in the ATX power cable, because I was already running wires there for the +12v from the OPUS.
  3. #103
    Jul 2004
    Chandler, AZ (Phoenix)
    Quote Originally Posted by rando
    Yes, that's correct. Here's a schematic.
    thanks rando! I implemented your schematic and it works like a charm
  4. #104
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    The diagram is just a schematic. It doesn't tell you how/where to grab your power sources or grounds. There are MANY other posts on this site and elsewhere around the web that discuss proper power distribution and grounding techniques. In the case of the relay just use whatever ground source is most convenient -- but make sure it is a good ground. Your systems common ground point, battery negative terminal, or a ground from one of your 4-pin molex connectors are all good choices.
    @brage: Cool, I'm glad it worked for someone else.
  5. #105
    Jul 2004
    2 Questions from an electronics n00b:
    1. Must I do this mod or my battery will die? Or can my battery tolerate this type of drain overnight on a regular basis?
    2. I don't know how to read a schematic. Any help or links on schematics / relays etc available that can help me decifer what I need to do?
  6. #106
    Mar 2004
    If I didn't run my car for two days it the battery was too low to start it. I have a Mini-ITX, USB GPS/Keyboard/Wifi/Touchscreen.
  7. #107
    Constant Bitrate KaiTech's Avatar
    Opus is releasing any day now a new power supply, 5V & 12V or 12V. From what i understand it's possible it's going to be cheap. That would solve all USB powerdown problems. Also i know this wont help all that already have an OPUS 150W but the next revision is going to be a 200-220W with 5STBY shutdown option, and that should be out in less than a month or two.
  8. #108
    Jul 2004
    That sux ballz
    I just bought my Opus 150W like a week ago
  9. #109
    Quote Originally Posted by Jackboot
    That sux ballz
    LIFE...
  10. #110
    Constant Bitrate Xtreme2k2's Avatar
    May 2004
    NJ
    Does anyone know when that new PSU is due out?
    I just fried my opus 90 () and was looking at the 150, but if theres a new one coming out..
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  4. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
