Page 14 of 20 FirstFirst ... 4567891011121314151617181920 LastLast
Results 131 to 140 of 198
Thread: Looking for a creative solution: USB bus still powered after CPU is off
  1. #131
    Low Bitrate BlueGrimRX8's Avatar
    Dec 2004
    Jacksonville
    I guess its my turn to revive this really old thread.....just a few clarifications after reading over and over everything in this thread.
    1. It will be best to use a DPST relay correct?
    2. I plan to run power from the 5V side of a Molex connector to a USB hub. Can I just cut the power cord that is supplied with the Hub and connect the 5V from the Molex connector to the positive and negative wires that I cut on the hub.
    3. If I do #2 and complete the mod described in this thread, then no power will be provided to the Hub unless the CarPC is on?
    4. I also plan to use the 12V side of a molex connector to power my lilliput monitor. This mod and the USB mod described above will not interfere with that correct?
    Thanks for all the great help as always.
  2. #132
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by BlueGrimRX8
    Yes
    Yes
    Yes
    Yes
    You're welcome.
  3. #133
    Mar 2004
    I don't know if this helps, but I solved a similar problem by using a LED and a photo cell. I have a remote computer (server) with USB drives connected. My problem was not having access to turn on/off the computer and USB hard drives. I connected an isolated wireless switch, not the type you buy at Menards, Low's, Etc., to the power on/off button of the computer. I then connected a LED to the 5v line of a molex connector going to my hard drive, and optically couppled it to a light sensistive switch I made using an 741 op amp and a switching transistor connected to a 12 v relay. This is how it works: When I want to listen to music, I push my remote button on my key chain, the computer powers up and turns on the LED. This, in turn, activates my light sensitive circuit turning on my USB devices. When I am done I stop MC. I have Hibernation set for 5 minutes after which time, the computer shuts down. When This happens the LED goes out and the light sensitive switch deactivates, removing power from my USB hard drives. Works for me
  4. #134
    Apr 2001
    Portland OR
    You could just use a shutdown controller. That is one of the main features of the uSDC20D. When you don't want the computer drawing power, it doesn't. It goes down to .000050 amps. You can hook it up to your computer and your monitor. It even has an Aux output you can connect to amps and stuff.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  5. #135
    Dec 2004
    Jacksonville
    I have the Opus 150W Power supply so I don't think that that is an option.....
    Thanks Rando for the quick reply!!!!
  6. #136
    Taz
    Taz is offline
    Jan 2005
    Have not tested it,but think i works..
  7. #137
    Mar 2004
    Redondo Beach, CA
    @Taz: This solution was already discussed higher up in this thread. It doesn't work because it requires the Opus to tolerate the IGN line going high before the Battery line. It was discovered that the Opus power up only worked intermittently under such a scenario.
  8. #138
    Dec 2004
    Jacksonville
    Worked like a CHARM, I just can't believe I made my first eletrical itemm!!!
  9. #139
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Wow! I mean WOOOOOW!!!!
    Quote Originally Posted by rando
    Yes, that's correct. Here's a schematic.
    Rando,
    I'll have to do some digging to find the schematic for my motherboard, but thanks for the info! I looked at the parts in post 125... can you verify those are sufficient for this mod? I really appreciate all you've done with this! Did you have any adverse effects from the hub not being powered up? I'm running a USB keyboard on the hub and I'm concerned the PC won't see it if the hub and PC are shut down for a few days.
    Care to speculate why OPUS didn't take care of this for us?!?!
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  10. #140
    i sent mine back to Opus and they fixed it by changing the firmware and something else.. turned it around in 1 day, didn't charge me shipping back to Canada either.. now my Opus 150w is completely off (including all USB devices) when i shut it down.
    Craig
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  4. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
