Page 2 of 20 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 198
Thread: Looking for a creative solution: USB bus still powered after CPU is off
  1. #11
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    @Curiosity - I think the hub will still accept power from the bus even when something is plugged into the 5v jack.
    Is it possible to disable a hub from utilizing / accepting bus power?
  2. #12
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Cut the red wire! Seriously, but open the hub and cut the trace coming from the computer's power (usually the red wire).
  3. #13
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I "think" the hub is probably set up to open a set of contacts to keep the 5v supplies from fighting. Kinda like when you plug in a set of headphones to a headphone jack and it cuts off the speakers. This may not be true, but I would think they would have to. You may end up having to trim the 5v+ wire going to the usb. Here is a very (ready VERY!!!) basic drawing of how I would try hooking it up. I found a website with this info..."The maximum current the fan headers can provide is 0.5A. The maximum 12v fan power that the motherboard can support on each header is 6W"....which tells me a relay should be no sweat for it. But again, I would like to hear from the electronic guru's here to be safe.
    2005 Ford Focus ST
  4. #14
    Feb 2004
    Menlo Park, CA
    Speed Racer
    Could that be done with the main 12v line from the battery to the computer. Id much rather cut power there AND the USB hub power supply. How would i go about doing that?
    2003 Subaru Impreza TS
    Staus: Done.. too lazy to make pictures lol.
  5. #15
    Dec 2003
    Portland, OR
    Not sure that I follow completely. My idea was to use the fan header to turn off the power to the hub...are you asking about using the 12v to the board to kill the usb? in that case I would think so. If you want to cut all power on the 12v line to the pc, I would not recommend a relay, it will be huge and will be more difficult to wire up.
    2005 Ford Focus ST
  6. #16
    Jan 2004
    Seattle, WA
    I'm starting to think about this, tell me if it makes sense:
    The front USB ports are NOT integrated into the mobo, therfore they have an actual connector that plugs into the mobo. What if a relay of sorts was wired into the particular power line here on the connector, which would be triggered to turn the power off based on the PC being shut down?
  7. #17
    Dec 2003
    Portland, OR
    Quote Originally Posted by S4Per
    Suppose it would work, but I dont think powering a relay off a usb port will be that good. I prefer the fan connector because it is made for higher current draws.
    I think I may be misunderstanding you though. Are you trying to turn off the usb's or cut power to the whole system?
    2005 Ford Focus ST
  8. #18
    Feb 2004
    Menlo Park, CA
    Personally I want to cut main power to the Opus after it has triggered the shutdown of the system so that the USB ports dont have power. I also want it to reset quicky so when i turn the car to ACC or further the computer comes on without having to push any buttons other than turning the key.
  9. #19
    Apr 2003
    Quote Originally Posted by Maeveth
    I agree. That's what I have in my setup - a shutdown controller that cuts power off to the Opus 30 seconds after ACC goes off. Otherwise, my USB devices (Lilliput touchscreen controller and USB GPS) draw enough power to drain the battery after a couple of days.
  10. #20
    Raw Wave
    Jun 2003
    gospeed.racer,
    The problem with using the fan connector is that the motherboard must turn the fan on all the time as long as the PC is on...noisy to some poeple and some BIOS may not support "fan on" at all time. There are some "sensitive" relays these can be swithed on with minimal current if you need to use one.
    Such as :
    http://www.maplin.co.uk/products/mod...599&Products=2
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  4. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
