Page 6 of 20 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 198
Thread: Looking for a creative solution: USB bus still powered after CPU is off
  1. #51
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    OK, so there are a couple of issues with Ricky's mod.
    First, his circuit (initially) powers the opus from the car's ign/acc line. That may be fine on some cars, but in general, is a bad idea. You don't want to try to draw (upto) 15A from your ignition line. Since it's just used to bootstrap the Opus, it probably only draws a few amps max. Just the same, that's a heavy load as far as the ACC line is concerned. That's why most of us have run a custom circuit to supply the 12v line on the opus.
    Second (and probably worse), once the Opus turns on, the 12v line and ign lines in your car will be shorted. The 12v line is probalby a high current line with large guage wire. The ignition circuit (being a low current circuit) is almost certainly using 18-24guage wire. Ignition circuits are usually protected by 15A or less (7A in my truck) fuses. If an ACC line shorts anywhere in your car, it is liable to release magic black smoke since the ACC fuse will no longer protect it. THIS IS BAD. VERY VERY BAD.
    There is an easy solution. Use two relays. The switch side of the relays are in parallel and switch the 12v line. Hook up one of the coils through a 12v output of the opus. Hook up the other coil to the ACC line. Throw in a couple of diodes to block EMF if you like.
    Instead of the second relay, you could also try throwing in a couple of diodes to assure that the ACC and 12v lines stay isolated. This would have the annoying side effect of lowering your 12v line input voltage and thus the opus' low batter protection circuit would then kick-in sooner.
    Good luck.
  2. #52
    Raw Wave
    Jun 2003
    Rondo,
    Glad you found something wrong with the mods before someone smoked up As I said its not tested and I didnt even gave much thought into it.
    Im not so sure how your mods are all wired up, please draw the diagram for us
    Not that I need it, Im just curious how it works...maybe someone can use it.
  3. #53
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I kinda had the same thing happen to me, I had one computer that WOULD NOT power off, i was sitting there with the power cord in my hand, and that stupid LED on the mother board was still lit. Long story short, power was coming from another computer via firewire powering the +5v on that computer.
    Anyway, most cars now have current being drawn from them when the key is off.. ie car's internal computer, clocks, etc. I would measure how much is being drawn via your USB, it might not be that much. You could also take the hot (or ground) wire off the battery and measure the total current draw of your vehicle while the key is off. If your battery is being killed by this little amount of current, you might want to check and see if your battery might be getting old.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  4. #54
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I was wondering if this would work:
    I modified Rickys drawing (hope you don't mind) to save time (see pic). I set the relay on the OPUS 12V in to be powered by the IGN ine and the OPUS 12V output (eg HDD power connecter) so whn your IGN turns on it not only switches on the power to the OPUS but also triggers it into booting via the IGN line into the OPUS. When the IGN is turned off the OPUS continues to power the relay thus self sustaining itself while the drop in the IGN triggers the shut down. When the shut down turns off the OPUS 12V output it then kills its own power.
    Not really familiar with the way the OPUS works and electronics are not my strong point so PLEASE COMMENT AS TO IF THIS WILL WORK. I put the diodes into the relay inputs to isolate them - think they are the right way round.
    Andy
  5. #55
    Mar 2004
    Redondo Beach, CA
    Scouse Monkey's circuit looks good to me. You can also use 2 relays connected as below.
    Connect ACC line directly to Opus ACC input
    ACC--------------OPUSACC
    Connect +12V battery to Opus through relay switch. Switch is controlled by ACC line.
    ACC-----COIL1------GND
    +12V----SW1------OPUS+12VIN
    Connect +12V battery to Opus through relay switch. Switch is controlled by OPUS +12V output.
    OPUS+12OUT-------COIL2---------GND
    +12V----SW2------OPUS+12VIN
  6. #56
    Raw Wave
    Jun 2003
    Scouse Monkey,
    Yes your circuit look good as it eliminate having to use 2 relays. It look like its the best solutions so far.
    Rando,
    I can see how your circuit working now, thanks for the diagram.
    Both circuit should work but as I mentioned on the original diagram a delay is most likley needed when triggerring the OPUS ACC. On both circuit the OPUS ACC get the +12V first before the OPUS +12V.
    Ill say a proper operation should be :
    +12V to OPUS +12V supply
    1 second or so delay
    +12V to OPUS ACC input
    I dont know how much current the OPUS ACC input takes in and what voltage it triggers at. I cant see it taking so much current in so a resistor and capacitor should work fine to delay the ACC trigger.
    Ill like to see a final circuit working, Sorry I cant help out on testing as I dont have an OPUS.
    Keep the ideas comming in...this what keep the forum going
  7. #57
    Mar 2004
    Redondo Beach, CA
    Are you sure the delay is required for the Opus? I'm going to wire mine up with the 2 relay solution today. I'll let you know if it still works.
  8. #58
    Raw Wave
    Jun 2003
    No, Im not sure but its something I expect. But please do try it without any delays and see how it goes
  9. #59
    Mar 2004
    Redondo Beach, CA
    OK, I wired it up with 1 relay and two diodes ... basically the same as Scouse Monkey's circuit minus the diode across the relay. With the key off, the Opus is completely powerless. With the key turned on, the Opus comes on and then fires up the CPU after a few seconds. When I shut the key off again, the Opus signals the CPU to shutdown. Once the CPU turns off, the Opus turns COMPLETELY off again.
    At least in this case, the Opus doesn't appear to have any problem with the ACC line going high before the +12v line.
    As for the diode across the relay, I don't think it's needed since both lines feeding the relay are already protected by their own diodes. The EMF generated by the coil field collapsing has nowhere to go. Then again, I may be totally wrong about that.
  10. #60
    Raw Wave
    Jun 2003
    Nice one,
    I guesss the modified circuit diagram can be redrawn and finalised everything for the benefits of other user.
    On the diagram its probably easier to tap the +12V output of the OPUS from the HDD/CDROM supply. Not so sure about the diode across the relay either in this case. Putting an extra diode wont hurt, its better to be safe than sory until someone can confirm it is safe without it.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  4. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
