Just curious, why did you decide not to use the relay?
Hi All,
We had a thread on this the other day, and the solution I implemented is slightly different than the one that was proposed.
Problem: USB bus stays powered even after Opus shuts down computer, thereby draining the battery. Secondly - I needed to power my USB hub.
Solution: I have 6 USB ports on the Shuttle, but unfortunately the 4 on the back of the computer are integrated into the board. The two front ones are not, and therefore have a cable that connects the ports to the mobo. Here - we spliced in a relay for the two USB ports (splicing into the power lines) that is powered by the molex connector. So - power is supplied to the bus only when the hard drive (for example) is powered. In essence, as soon as the computer shuts down, so does power to the bus. The second relay is essentially the same, except that it's for the 5v line that runs from another molex connector to the USB hub. So - power is supplied to the hub only when the computer is on.
It's essentially like the solution that was drawn up on the other thread, but note that no diode's, and therefore no drop in voltage, were necessary to do this. It works like a charm.
Thanks for all of the help and suggestions.
-Per
Not sure what you mean. I used two relay's, but no diode's.
So, relay 1: from HD connector to 2 front USB ports (power down ports when computer shuts down), and
Relay 2: from HD connector to USB hub power (power down hub when computer shuts down).
-Per
S4Per read shchua post #31 on :
Looking for a creative solution: USB bus still powered after CPU is off
Its a protection diode and you do need it...theres no voltage lost concern in that.
You dont wanna risk damaging your PSU, HDD or anything thats connected to that relay coil...I did say dont miss that diode...and do connect it the right way.
Glad you got it working anyway.
a-ha...thanks much for the pointer. looks like i'll need to get that in there. thanks again!
Do you need BOTH 5V power sources? Would this work with using only one relay on either the hub external power supply or the 5v power off the motherboard USB connector feeding the hub? Thereby eliminating one or the other power source?
System:
Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
Others who are considering doing this may want to look for a DP (Double Pole) relay. In this application a DP would do the same job as two relays, but would save some wiring etc. You would connect the bus to one pole, and the PS to the other.Originally Posted by S4Per
Is anyone doing anything similar to this to control the power to their monitor? This way if you wanted to have the screen on when the car is off, but the computer running, but not supply power to the monitor to save the battery you could.
S4Per,
Do you HAVE to have two seperate sources for power and why?
MUSC5vette,
I currently use a relay to power up/down my LCD display.
System:
http://www.maplin.co.uk/Search/results.asp?CartId=040417214534929&Level=1&Menu=18 &Name=Relays
As MSUC5Vette advised :
Yes use DPDT relays on the list and save a diode too![]()
