Install coming up... but Power questions
I have been lingering on this forum for months, but this is my first post. I have searched on this subject and read much, but still have lingering questions (complete power/wiring moron, so keep-it-simple :) ). I know they are noobie in nature, but thought they might be appropriate in Power forum.
1. I have in my possession Opus 150 W. Does power from + battery terminal connects to red?, and black is ground?, and blue is remote? (guessing here)
2. What gauge wire are you using for those three wires (i.e. power from battery to Opus, remote, and ground)?
3. Does the wire from + battery terminal to Opus need a fuse? If so, what "strength" of fuse (oh boy, that sounds pretty imbecilic, sorry :( )
4. Where is the best place to connect the remote wire? Do you just pick a wire under the steering column and voltmeter it (which is a tool I don't have... yet)?
5. Next biggie, is how to power the Lilliput screen.
a. Do people run power to the screen from the Opus, and if so, where do you run the power line from on the Opus unit?
b. Can you run 12V of power directly from battery, if so, do you need it regulated and/or do you need a fuse?
b. Or, do people prefer chopping off the end of the AC adapter and running that to the back of a lighter or some other 12V power source under the steering column?
6. Wondering how people power external DC items like drives and hubs. I know that I can use an inverter, but can I use the Opus for this too. Specifically, I have an IDE to USB inverter cable for my DVD ROM drive and I need to power that conversion cable. I would like to use the Opus but where do I run power out from on the Opus unit and how do I connect it to the DC plug? Do I have to hack off the wall plug and connect wires? Or, do you fashion some sort of female receiving plug for the items male plug?
Well, painfully dumb questions have come to a close for now, I appreciate any efforts to help me out. Thanks.
