Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Dashwerks shutdown controller
    Newbie Lacoste's Avatar
    Oct 2003
    Cool Dashwerks shutdown controller
    This looks kind of interesting. I like the LED leads it provides. Functionally, how different is this from the ITPS?
    Lacoste
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    Looks kinda big...
    Edit: Then again, it has a lot of nifty features.
    Raw Wave
    Jun 2003
    Yes it is big for what it can do...im sure they can use SMD. The power relay is probably much better put off-board so then user can place it closer to the PSU/AMP and battery.
    I didnt like idea of loosing a com port and having to install a software for it. I wonder if it still possible to get the PC out of sync with the ignition key.
    Oct 2003
    Vancouver, BC
    If you're going to use a serial port, why not just pull 5V from the power supply and relay it with the ignition to pin 8 of the serial port? If you setup Windows with a UPS, it'll automatically shut down.
    IQ < 70
    Mar 2004
    what?? what does this exactly do? do you need another power supply and this regulates it? does this act as a power supply? i don't see the same connectors, how does it exactly work? whammo
    IQ < 70
    Mar 2004
    and does it provide support for a p4 chip?
    Jan 2004
    Software and drivers are NOT required for the DSSC
    Software drivers are only required if you want to use the serial port shutdown feature of the DSSC. If you don't use any software, it will work with any ACPI enabled motherboard (P4) included. You simply connect the ACPI/power switch header of your motherboard to this circuit and it will turn your motherboard on and off with your car. It will also turn off the main power to your carpc by using an offboard Relay (not pictured).
    Details about it can be found here. Click on the DSSC Startup/Shutdown link.
    Best regards,
    CB
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    is it still on pre-orders?
    Lot of modders would be interested in this device, if they could actually get it.
    -Mars
    Constant Bitrate cbergeron's Avatar
    It's available for purchase - here's the link: http://www.dashwerks.com/dw_dssc.php
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    Apr 2001
    Portland OR
    The uSDC20D is a more compact solution, and you can buy it on this website. And it has a temperature sensor, and it probably draws less current in the off state, and it was designed by me :-)
    The uSDC20D will power a P4 if your using an inverter. It is really the only way to go if you want to use a power hog computer in your car and still save your battery when it is off for a while
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 09:30 PM
  3. hooking up the Jeff Muchas shutdown controller?
    By jusatry in forum General Hardware Discussion
    Last Post: 03-12-2004, 12:43 PM
  4. What do you want in a shutdown controller?
    By meddler in forum Power Supplies
    Last Post: 02-12-2004, 03:40 AM
  5. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
