Results 1 to 6 of 6
Thread: How much power?????
    Leeds, West Yorks.
    How much power?????
    how much power do i need from an inverter? will 300w do? or is that too much/little?
    Low Bitrate Insight's Avatar
    Depends on your carputer power supply. A 300W inverter does not give you 300W if you read the back of the box its surge capacity is 300W and it will give you a continous flow of power less than that, I think 80% of that. If you are using an OPUS 150W PS you need at least 175W inverter. I have a thinkpad wired it has a 60W PS I have a 75W inverter.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Why would an opus need an inverter insight?
    anyway he's right get something with a continous flow of power at or more then what your psu puts out. Its always better to go little bigger.
    Mine needs to be updated.
    Jan 2004
    st charles, mo
    i run a 175watt inverter that surges to 300watt, with a 250 watt powersupply. no problem
    Aug 2003
    San Diego, California
    Quote Originally Posted by kram
    that means you *could* be using a 180 watt ps, and no problem.
    Quote Originally Posted by samc
    I went OPUS but I figured the inverter part out when I needed to power my laptop in my car before a carpc was a twinkle in my eye
    CarPC
    VIA Nehemiah M10000, 256MB RAM, 40GB HDD
    100W DC PS /w ITPS, TV tuner, Slim Slot-Load DVD
    GPS, Streets and Trips 2004, Rearview Camera
    Bluetooth, 802.11b & CDMA 1X
    In-dash 7in Lilliput Touchscreen
  1. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  2. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  3. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
