PM Mastero, the 2 are basically the same.
I need a controler that will simply control a master relay and pulse my power button upon ignition on and ignition off. Jeff Mucha seems to have the best controller for my needs, does anyone have anything like it. He seems to be tied up. This is the last component i need for flawless operation.
-Jack
2006 Chrysler 300C AWD
Samsung Galaxy Tab In dash
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Get the ITPS from here. Works great.
Edit: You can attach the output of the ITPS to your master relay if you don't want that to supply power to your setup.
Be aware though that the ITPS shuts down after about 30 seconds when ignition is lost, whereas the shutdown controllers have programmable timers. (well pots) and can give you upto 30 mins before the PC shuts down.
Craig
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
