The easiest way to tell would be to hook up your setup in the house, using a normal PC power supply, then connect a multimeter and see how much current it pulls. Typically boot up time is the biggest power draw, since all the drives spin up at once and the processor is busy loading the OS.
If you're over the 150 watts of the Opus, you can always switch to laptop hard drive and optical drives. That will reduce your power consumption significantly. Typical hard drives can soak up 25 to 30 watts, whereas a laptop hard drive will only use about 5. You motherboard is probably in the 60-70 watt range. I don't know about the AGP graphics card. But from that calculation you're running pretty close to the 150. It would be worth measuring it with a meter.
LinkBack URL
About LinkBacks
