Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Should everything be powered by OPUS?
  1. #11
    Constant Bitrate gubon13's Avatar
    Los Angeles
    lol - i was wondering about that... seemed like it was too good to be true that such a nice usb audio devices was powered solely by the usb bus. i wouldn't know since i haven't even SEEN one in person. sad - i know... at least my excuse is that i don't work computer retail any more. lol.
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
  2. #12
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by jusatry
    gubon - good post.
    one correction - if you power the screen off the opus, it will come on with startup/shutdown of opus (ignition). just thought i would throw one factor that may persuade you TO power it off the opus.
    the Lilliput won't turn on on it's own, you'd have to do Coyotes mod or something like...
  3. #13
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    laidback-
    yeah, i meant to add that - but if you hardwire it to a B+ source, you either need to wire a relay from teh ign wire or have it on all the time (then coyote's mod doesnt work).
    but if he powers it from the opus (with coote's mod), it will come on/off with the power.
  4. #14
    Oct 2003
    Madrid
    ok, and I just read another post where a guy who's just got a lilli says it turns on when power is applied!!
    My solution to Auto Power ON Lilliput screen
    maybe they changed them?
  5. #15
    Los Angeles
    odd. mine's fairly new but it doesn't do that. i gotta get off my *** and do the coyote mod. pulling out the remote is getting annoying - i drive a LOT.
  6. #16
    Constant Bitrate c0rrupti0n's Avatar
    Mar 2004
    Miami
    Quote Originally Posted by gubon13
    Yeah i already did the coyote mod. It works well...
  7. #17
    Mar 2004
    Miami
    Thank you all for your insight. I plan to run everything off the OPUS... I just have a few questions. Pardon me if i sound nieve, but unfamilar with electric wiring an such.
    Is there a way to power everything from a single large guage wire from the OPUS?
    If so, how is the voltage regulated between devices and how are they connected?
    Or do I just seperate power cables for each device?
    Does length in those power cables cost additional power?
    Thanks so much...
  8. #18
    Los Angeles
    I would go with the individual power wires. It is technically the same as the single large wire with taps on it for each device, but it will be easier to make changes with individual wires. As for power regulation, the OPUS unit does that, but it does so on the 12V rail on the whole, so each device would NOT be individually regulated except by internal electronics. The power supply does not do this.
    Also, yes - distance will effect your power signal. Depending on amperage, voltage, wire size, and quality of wire, signal degrades faster or slower. All signals degrade over distance. For the wire choice, see this chart for help:
    http://www.sdcsecurity.com/2002pdfs/ps/wire.pdf
    Also, a run through http://www.the12volt.com will make you feel like a pro. It's one of the best car electronics sites available, with TONS of resources and information.
  9. #19
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    one of my favourite webite for car electronics is www.bcae1.com absolutely brilliant!!!!!!!!!
  10. #20
    Mar 2004
    Miami
    After reviewing those site, it seem that i shouldnt be conserned about length unless im talking atleast 50 or more feet...
  1. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 03:17 PM
  2. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  3. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
  4. Can the Opus be powered by an adapter?
    Last Post: 09-09-2003, 02:52 PM
  5. Replies: 3
    Last Post: 05-28-2003, 10:45 AM
