Yes, that is called 'efficiency' and it is one of the Opus's big strengths.
hi, just a quick question which im guessing is really stupid, but if I was to buy an OPUS unit and power a pc from that, will this consume less power than using a invertors to pc?
I guessing it will use less, since there’s little conversion taking place.
ta. just needed to check. My invertor just drains far too much power for my car
Once i get my OPUS is it worth getting a bigger battery as well?
you don't need a second battery.
If your setup cannot keep one battery charged, then it cannot charge two-get a better alternator.
However, if you plan on running your system without your engine running, having two batteries will keep your system up twice as long.
EDIT:
Oops - you said bigger battery not second. It's always a good idea to get the best battery you can afford. Not just for a carputer, but in any car so that you have the needed cranking amps after running accessories.
If at first you don't succeed, so much for skydiving!
