Results 1 to 7 of 7
Thread: Capacitor before a DC-DC
    Newbie panelrodder_81's Avatar
    Mar 2004
    Saratoga Springs, Utah
    I've been crusin' the different forums just reading and not posting. This is my first post and haven't found anything like this here yet. Couldn't you simply hook up a car audio capacitor before your DC_DC power supply to avoid the cranking issues? If you had a relay triggered by the ignition switch to turn on the computer, or just had a switch to turn it on, and the main power coming off of the cap you should be able to crank all day long and not have problems, unless your cap is small and doesn't have the power on hand. Right? If your cap was big enough you could even run the computer for a little bit after the car was off, really only for shut down or entering hybernation though. It seems to me that it should react the same way as having a UPS or something hooked up right? Again, my first post and I'm new to the car PC thing to boot!
    PanelRodder
    www.brigham.net/~jacobh/barndoors/
    Panelrodder
    1953 GMC Panel Truck
    2007 Pontiac G6
    2008 Chevrolet Silverado
    www.lunacium.com
    Dec 2002
    Chico, Ca
    Well for a first post it's not bad but there has been plenty of study on this one. Heck, a few of the guys around here have even done the math to figure out how big of a cap it would take and the end result is it would be one big fat cap. Way bigger then the caps used for car audio stuff. Why spend 200 dollars on a cap when you can spend 15 bucks on a battery?
    I'm sure others will chime in with the details on this subject though. Keep up the reading and welcome to the boards.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by panelrodder_81
    Yep, but you'll need a huge capacitor:
    http://www.mp3car.com/vbulletin/show...63&postcount=5
    Capacitors aren't a magic store of infinite power. There are very few success stories, if any:
    For those who tried the 1F tank!!!
    A second battery is a better choice. A decent DC to DC power supply that will cope with the dip in voltage is even better.
    Maximum Bitrate none's Avatar
    Sep 2003
    The flaw with Ricky's equation is that he is assuming total voltage loss when starting. That doesn't happen, only a momentary dip - the largest amplitude of that dip lasting only milliseconds. The equation also does not even address current, which is just as important.
    That said, for 99.9% of these applications a battery is better. But a capacitor can work with the right PSU (Keypower especially but NEVER a mini-box PW-XX, those things are crap.)
    Mar 2004
    Ok. I guess I just opened a the MOTHER of all can of worms! For some reason I wasn't able to find all those posts on the capacitor before I posted. It seems that we should just leave this alone. The logic of both sides seems to make sense. It seems that no one has yet to actually try a 1F cap on the system though. I've got a friend with one in his audio system. When I actually build the system I'll borrow it and try it since it seems no one else is willing to.
    Panelrodder
    2007 Pontiac G6
    www.lunacium.com
    Sep 2003
    http://www.mp3car.com/vbulletin/power-supplies/23937-keypower-250-watt-stock-battery-no-reboot-on-crank.html#post180949
    Help with Tank Circuit
    It has been done successfully. There are just as many or more failures as the above success stories, however. Depends on the car and PSU.
    BTW, good to see another Utahn here.
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I have a KeyPower PS and was gonna add a battery backup.
    But I added a 1 Farad cap for my two amps, and to my suprise, my car now survives cranks.
    I paid $120.00 for my cap, it's a Stinger brand with blue neon, and blue LED's that go with the beat.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. Inverter vs DC to DC
    By MattPociask in forum Power Supplies
    Last Post: 05-01-2004, 04:10 PM
  2. DC to DC converter
    By jdub421 in forum Power Supplies
    Last Post: 02-03-2004, 04:17 AM
  3. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 05:25 PM
  4. Powering IDE HD with DC to DC
    By Destin in forum General Hardware Discussion
    Last Post: 12-19-2000, 09:07 AM
  5. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
