Results 1 to 7 of 7
Thread: How Many Watts?
    Aug 2002
    California
    How Many Watts?
    How many watts do you think I need to run an Epia- M10000 (Nehim-whatever core) a mini DVD-drive, a 76gb 7200rpm 3.5in drive and a Sb live 5.1 sound card. Thanks. My case has a 65watt powersupply and I think that is not as much as I need.
    2003 Audi A4 1.8t (Totaled, Project Canceled)
    Constant Bitrate gubon13's Avatar
    Los Angeles
    The M10000 board is rated at 24W under load (this includes the CPU). 512MB PC2700 is going to use anywhere from 5-15W under load. Slimline DVD-ROM runs 5-10W under load. Typical 7200RPM desktop hdd runs anywhere from 5-15W under load. All USB devices can have a maximum of 2.5W under load. I assume the screen will be powered by the car's battery, and not the PSU. So at most, the total is (m/b+cpu)24W+(RAM)15W+(DVD-ROM)10W+(hdd)15W+(usb device:griffin)2.5W = 66.5W. And this is at MAXIMUM values, not including the SB, as I don't know if it's internal or external - but figure 10W max internal, and obviously 2.5W for external, but it would still need the external power adapter. Any extra usb device would be 2.5W.
    My guess is that it will NOT be sufficient.
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    If that's all you're running, 70 watts should be fine (at least 60 watts continuous).
    If at first you don't succeed, so much for skydiving!
    Newbie chavoush's Avatar
    San Antonio
    power supply
    Currently have m10000 with casetroniic 2699 and buillt in power supply i thiink it's 55W and have been able to run MoBo 3.5 ide and full size 5inch dvd rom, ps2
    mouse and usb Kb witth no problems but when I also added on 2.5inch HD system didn't boot.
    Hope this was helpfull
    dk
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    similair deal with mine, casetronic morex 55 watt on a Via "m" board, 250gb hard drive, and laptop combo =ok, but if i take out the laptop cd drive and go full size, it wont boot.
    2005 Ford Focus ST
    Los Angeles
    I guess I'm just precautious... I would be hesitant because IN THEORY it should not be sufficient, but that's dealing with theoretical MAXIMUMS.
    (And I always drive the speed limit and cook meat all the way through.) =) LOL
    Honestly, it's easiest just to look up the devices in the manuals or online and add it all up. I figure it's better to be safe than sorry.
    Because you know, when you're searching for a gps signal while playing mp3s and a divx file while ripping a rented dvd as you're playing MAME and all of your devices hit maximum and the psu goes up in flames...don't come crying to me... lol...
    San Antonio
    Wow, you're doing all that while driving
  1. How many watts do I need?
    By maxcosity in forum General Hardware Discussion
    Last Post: 04-21-2003, 02:10 AM
  2. How many watts?
    By eddieo in forum General Hardware Discussion
    Last Post: 12-14-2000, 09:29 AM
  3. How do I know how many Watts??
    By HunterC47 in forum General Hardware Discussion
    Last Post: 07-20-2000, 12:13 AM
  4. Inverter 150 watts
    By prado_sergio in forum General Hardware Discussion
    Last Post: 11-09-1999, 03:24 AM
  5. Inverter 120 watts
    Last Post: 11-09-1999, 02:50 AM
