@Bitflip, I don't understand your first question entirely. Yes, you can leave your PC on all the time while the engine is running. Once you stop the Engine, the Opus will handle shutting down your PC and the PSU so that your battery isn't drained. If you want, you can also add your own switch(es) to add manual overrides to this behavior. I have no idea if the Opus has enough
power to supply your Shuttle. Search around.
If you want a fuse to protect the wire running from the battery to the Opus then the correct current rating for the fuse depends on the current carrying capacity of the wire you use. Use the search button. There are several threads with links to wire and fuse sizing guides.
