Results 1 to 8 of 8
Thread: wont run while engine on
    Mar 2004
    got all my stuff installed. did all my testing, everything works great.
    using pw70a w/relay setup (no ITPS)
    problem is, it will remain on through starting the engine, but w/in 5 seconds it shuts down and will not restart (i guess thats a brownout)
    what gives?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    What does your voltage read on the lines for power? When engine is off and when on.
    Mar 2004
    engine off, ACC on = 12V
    engine on = 14.5V
    cranking = 9.5V
    Mar 2004
    specs on ituner say 12Vin = 12 +/- 15%
    is that right?
    that would be the problem then, cause that would mean it accepts 10.2V - 13.8V.
    Jan 2004
    Can you turn it on manually after the car is on and the voltage is at 14.5v? If you can then you probably just need a tank circuit that will keep the voltage up during crank. If it still doesn't work after the car has been started for a while it's got to be that 14.5v is just too much for it, you'll have to put a voltage regulator before it, theres been a bunch of other posts on here on voltage regulation.
    Also, make sure your running your power line directly to the battery with at least 10 guage or better wire.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Mar 2004
    it will NOT turn back on after it shuts off.
    i'm running 10ga wire, less than 12' of it.
    i haven't finished soldering the wires yet (they are just twisted) but i dont consider that a defining factor in the problem.
    about the regulation, i'm going to try running the PSU off a laptop adapter w/12Vout. see if it makes a difference.
    like i say, it stays on during crank. basically wont start or run while the engine is on.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I had that exact same problem
    14.5V = No Go for pw120?
    never solved it. I ended up buying a morex case w/ power supply
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Mar 2004
    i ran my battery dead today (oops). turns out with the computer running and the stereo cranked i only get about 10min.
    anyways... after i charged it partially, the computer started to run while the engine was on! however, about 5 min on the highway it restarted, then 3 min later shutdown.
    i'm guessing the running voltage was lower cause of the mostly drained battery, but as the alternator charged it, it got closer to full.
    i'm going to try a laptop dc adapter w/12Vout in before the pw70 and see if it is better.
  1. ARGH! Engine noise!!
    By JayKaye in forum Car Audio
    Last Post: 06-01-2008, 06:08 AM
  2. Routis 2004 with Media Engine
    By dodgetimes2 in forum GPS
    Last Post: 06-18-2004, 12:59 AM
  3. Adding text-to-speech functionality to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 04-19-2004, 02:38 AM
  4. you guys run your carputer with the engine off?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 01-14-2004, 06:39 AM
  5. Useing GPS with Media Engine and other Question
    By Twizted in forum ME Archive
    Last Post: 01-10-2004, 07:36 PM
