Results 1 to 10 of 13
Thread: Opus remote switch
    FLAC Chairboy's Avatar
    Jan 2004
    Opus remote switch
    Hi there,
    I'd like to rig my Opus 90 so that I can turn it on, even if the car is off, all without leaving my keys in it. This way, I can pcAnywhere or Remote Desktop into it from my home, then shut it down via windows when I am done.
    Any reason why this circuit will not work? The items in red are what I am adding. I figure putting a diode in line will prevent 12v from going back up the wrong pipe and causing shenanigans in my car circuitry.
    Thoughts?
    Raw Wave
    Jun 2003
    I cant see it not working...try it
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The only problem might be that the Opus will sense that the IGN line is still "hot", and once you shut it down from Windows, it will start the PC back up again. I seem to remember this happening one night for me...came out in the morning to a dead battery
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Raw Wave
    Jun 2003
    I thought hes controlling the remote on/off switch via the AUX remote of the alarm? or maybe not cause then he would have said so.
    If hes gonna leave the switch closed...yeah like you said the PC will restart.
    Jan 2004
    Ah, good to know, didn't realize the Opus would try to 'help' me out by restarting the PC.
    Ok, that might not be a deal breaker as I may just turn it off manually then, but I'd still like to be able to have it on independant of the IGN. Does my simple circuit cover the bases?
    Thanks!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    how would you trigger your spst relay? It's the same as just putting the 12v constant to the ignition line.
    Mine needs to be updated.
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    I've set it up the same way, except with 2 diodes. The switch also powers up my WLAN adapter.
    I'll check if opus starts up the pc if it is manually shut down. I thought it didn't.
    Raw Wave
    Jun 2003
    I would also suggest a diode on the battery side as well.
    I been thinking about that and it make sense but then I dont think it have any effect though.
    Raw Wave
    Jun 2003
    Via alarm aux remote control perhaps? remote central locking? That what Ill do anyway
    Just have to retrigger it if he wanted to extend the time.
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  3. FS: Opus 90watt with Remote Trigger
    By naevity in forum Classified Archive
    Last Post: 03-29-2004, 05:47 PM
  4. Power switch to the opus
    By XMen in forum Power Supplies
    Last Post: 02-04-2004, 03:22 PM
  5. Replies: 1
    Last Post: 12-31-2003, 01:30 PM
