Results 1 to 10 of 10
Thread: everytime I start car, the PC will reboot with dc-dc unit (input 10.8 - 26V)
    Mar 2004
    hi
    I have a dc-dc unit (input 10.8 - 26V) and Via epia M10000 and everytime I start car, the PC will reboot..
    what I need? A backup batery, diode and resistor?
    thank
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    answered so many times,
    Battery based tank circuit (tested)
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Nov 2003
    Marietta, GA
    Mashina,
    What kind of DC-DC is it? Who makes it?
    MikeH
    Mar 2004
    Quote Originally Posted by MikeH
    Mashina,
    I was bought it from www.emko.cz in my country (czech republic).. but they hasnt any information about this psu in english i have only this czech link http://www.emko.cz/emko_cz/index.html
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    altavista bable fish it to get it in English.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Constant Bitrate vull's Avatar
    Oct 2007
    dunno about the power supplies, but the EM-151 case looks coool
    m350 is smaller tho :\
    Feb 2010
    other ideas for helping this problem are as follows;
    cable upgrades, both ground and feed, but mainly feed (to prevent voltage drop while cranking, if its only 0.1 - 0.5 volt a good upgrade from say 10-12 gauge to 1-2 will make a massive difference over 2-3 meters)
    capacitors, depending on alot of things but the right cap circuit would keep the voltage high enough during a quick cranking session
    ensure that you have the pc connected directly to the battery via a relay instead of to the ACC/IGN lines as these lines have higher voltage lose with the other things connected to them along with the very thin cabling. at most the acc/ign line should only be used as a relay trigger
    tank circuit as previously described
    Dec 2006
    Quote Originally Posted by pyro1 View Post
    I think none of all this will solve the problem.
    Instead I'd use the M2-ATX as a better, crank surviving, DC-DC converter and once you get tired of EPIA you already have a power supply.
    But sure, a tiny 12V/3Ah dry battery and a 5A Schottky diode should also work but I've never tried it.
    Elsewhere
    I think that the OP has either sorted out the problem or given up in the past SIX FREAKIN' YEARS.
    vull Why would you resurrect a 6y/o thread and add nothing substantial to this discussion?
    I honestly don't get it.
    How about the Wiki?
    Oct 2007
    if you dont get it, then it doesnt mean that others dont
    lets all rant offtopic now? that's even more pointless
  1. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
